Click to visit BT.com
BT.com
Wishlist
Creative Airwave Wireless Bluetooth Speaker - Pink
Quicklinx: 8XBFWS00
Mfr#: 51MF8160AA001
Simplify your life with the Creative Airwave. Unlike other regular speakers, you can experience the convenience of one-touch pairing with its Near Field Communication (NFC) feature. You can also enjoy your music wirelessly on the go, as it comes with Bluetooth and a rechargeable built-in battery.
Tap and play!
The Creative Airwave features NFC technology which allows for easy, one-touch pairing by simply tapping your NFC-enabled Bluetooth smart device on the speaker.
Pair and stream
As for your smart devices that are not NFC-enabled, you can easily pair them with the Creative Airwave via Bluetooth using the conventional method.
Integrated Aux In
You can also enjoy your music by connecting directly to the speaker via the integrated analog Aux-in connector.
12 hours of non-stop music
Party all night long on a single charge! The Creative Airwave gives you up to 12 hours of playtime, so don't stop the music!
Built in Lithium polymer battery
With a built-in Lithium polymer battery, your Creative Airwave is truly portable and you're free to place your speaker almost anywhere you please. You can check your battery levels with voice prompts and the speaker LED also alerts you when you're low on battery. In addition, the battery level icon is displayed when paired with selected smartphones. The battery can be easily charged via a standard micro USB connection.
Great sound
The Creative Airwave houses two efficient 3? full-range drivers that produce stunning, room-filling sound despite its small size.
Clear voice calls
Turn your speaker into a speaker phone with the built-in concealed microphone for dialog clarity in your voice communications.
Make a statement
The Creative Airwave's unique design is a radical departure from the usual rectangular-shaped speakers. The chassis is constructed to minimize vibrations and the optimal 30-degree front baffle tilt projects audio directly to the listener. Available in four bold colors, its unique triangular-styled construction, geometric face panel design and smooth curves make it a refreshing addition to any setting.
Creative Airwave - speaker - for portable use - wireless
Speaker - portable
26 cm x 11 cm x 11 cm
890 g
Speaker Type
Active
Audio Amplifier
Integrated
Connectivity Interfaces
Bluetooth, NFC
Speaker System Details
1 x portable speaker
Speaker Details
Speaker - stereo - 2 - active
Pink
Built-in Decoders
SBC decoder, aptX
Power Options
USB charging
Speaker battery rechargeable - lithium polymer
Speaker - for portable use
Hands-Free Function
26 cm
11 cm
11 cm
890 g
Enclosure Colour
Pink
Speaker System
Speaker Type
Active
Audio Amplifier
Integrated
Bluetooth 3.0, Near Field Communication (NFC)
Bluetooth Profiles
Hands Free Profile (HFP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP)
Transmission Range
10 m
Built-in Decoders
SBC decoder, aptX
Speakers Included
1 x portable speaker - wireless
Speaker Details
Driver Details
Speaker : 2 x full-range driver - 3"
Connector Type
Audio line-in ( mini-phone stereo 3.5 mm )
USB charging cable
Power Source
Options
USB charging
Run Time (Up To)
12 hour(s)
