BT.com
Wishlist
Creative A520 - 5.1-channel PC multimedia home theatre speaker system - 37 Watt (Total)
Delivery
Standard Due date unavailable
Get explosive bass and realistic audio for better gaming and engaging movies, with five satellite speakers and a subwoofer
Give your games, music and movies a muc needed boost with the Creative A520 speaker system. Given their contemporary style and ease of use, they are the perfect choice for immersive multi channel surround sound, bringing to you all the benefits of Creative's leadership in audio technology. The five satellites make use of the two-inch drivers for crisp dialog and impressive effects, while the large subwoofer with a flared port tube and separate bass control provides you with the freedom to adjust your bass level and deliver the extra impact and oomph for all of your entertainment needs. The system also includes a wired remote for easy-to-reach and convenient control.
Package Contents:
-5x satellite speakers
-1x subwoofer with wired remote control
-1x Quick Start Guide
-1x Warranty/Technical Support leaflet
Creative A520 - speaker system - for PC
Speaker system - PC multimedia - 5.1-channel
3.5 kg
System Components
5 speakers, subwoofer
Speaker Type
Active
Nominal Output Power (Total)
37 Watt
Frequency Response
40 - 20000 Hz
Audio Amplifier
Integrated
Speaker System Details
5 x satellite speaker 5 Watt , 1 x subwoofer 12 Watt
Speaker system - for PC - 5.1-channel
3.5 kg
Dimensions (WxDxH) / Weight Details
Satellite speaker: 8 cm x 10.4 cm x 14.4 cm , Subwoofer: 19.2 cm x 19.2 cm x 23.5 cm
Speaker System
System Components
Speaker Type
Active
37 Watt
Frequency Response
40 - 20000 Hz
Signal-To-Noise Ratio
75 dB
Audio Amplifier
Integrated
Controls
Power on/off, volume, bass
Speakers Included
5 x satellite speaker - 5 Watt - wired , 1 x subwoofer - 12 Watt - wired
Driver Details
Satellite speaker: 1 x full-range driver
Driver Details (2nd speaker)
Subwoofer: 1 x subwoofer driver - 5.25"
Connector Type
Digital 5.1 channel audio line-in
Remote control
Remote Control
Remote control - cable
Remote Control Features
Volume control
Power Source
AC power adapter
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good speakers.
Reviewed by PiotrekV6 on 12/01/2012
Very good sound quality, also strong. I recommend.
Scroll to top
