Click to visit BT.com
BT.com
Wishlist
Corsair Vengeance M95 Performance MMO/RTS Gaming Mouse - White
Quicklinx: 8MBZWS00
Mfr#: CH-9000026-EU
Standard delivery Delivered within 3-5 working days
The Vengeance M95 laser gaming mouse is designed for the complex demands of massively multiplayer and real-time strategy games. It offers 15 intelligently positioned buttons, easy programming, and onboard storage to take customized macros with you on-the-go. The 8200 DPI laser sensor gives you accurate control during intense gaming sessions. The low-mass aluminum unibody structure is covered in soft-touch materials and designed for the comfort and ergonomics you need when you're playing for hours. Plus, Vengeance M95 is available in Arctic White and Gunmetal Black to match your system or your style.
Product features:
Precise tracking for highly accurate mouse control during demanding gaming sessions
15 programmable buttons
Easy access to frequently-used abilities, macros, button combinations, and spells
Second-generation control panel
Makes setup and customization easier than ever
Onboard profile storage
Settings and profiles are stored directly on the mouse so you can take them with you
Aluminum unibody design
Built for low weight, high rigidity, and optimal mass distribution
Selectable response time
Choose between 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms)
High-mass scroll wheel
Solid metal, rubberized scroll wheel for precise tactile feedback
20 million click switches
Highly durable buttons that stand up to hours of gaming
Soft-touch and textured surfaces
Outstanding comfort during multi-hour play sessions
PTFE glide pads
Low-friction glide pads ensure swift, precise movements
Corsair Vengeance M95 Performance MMO and RTS Gaming - mouse - USB - arctic white
Mouse
Wired - USB
Arctic white
160 g
Europe
Movement Detection Technology
Laser
Buttons Qty
15
Movement Resolution
8200 dpi
Performance
30 G maximum acceleration, 2 ms response time, 1 ms response time, 500 reports per second, 1000 reports per second, 125 reports per second, 8 ms response time, 250 reports per second, 4 ms response time, up to 150 inches per second
Profile switch, backlighting, polytetrafluoroethylene (PTFE) feet, on-the-fly DPI switching, rubberised scroll wheel, aluminium body, automatic surface quality detection
1 x USB cable - integrated - 1.8 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
2 years warranty
Mouse
160 g
Arctic white
Europe
Input Device
Wired
USB
Laser
Buttons Qty
15
Movement Resolution
8200 dpi
Performance
1 x USB - 4 pin USB Type A
System Requirements Details
Windows XP/Vista/7/8 - HD 35 MB
2 years warranty
Service & Support Details
