BT.com
Wishlist
Corsair Vengeance M90 Performance MMO/RTS Laser Gaming Mouse
Delivery
Standard Due date unavailable
The Vengeance M90 Laser Gaming Mouse: optimized for MMO and RTS gaming
In the world of gaming mice, one size doesn't fit all. If massively multiplayer and real-time strategy are your games, the M90 is designed for you with premium responsiveness, MMO-optimized design, and superior control.
Play multiple games, with multiple character types? Now you can set up your mouse performance and button configuration for each, and switch profiles directly from the mouse. Your profiles are stored in memory that's built-in to the Vengeance M90 laser gaming mouse, so you'll stay in control even when you switch PCs.
Enthusiast-grade 5,700 DPI laser sensor
You get maximum precision and response from the Avago Technologies ADNS-9500 LaserStream™ gaming sensor, even on high resolution displays. Outpace and dominate opposing players with less accurate or slower gaming mice.
15 intelligently positioned buttons, including nine macro key
The 15 fully programmable buttons are arranged and tuned for intuitive operation without compromising your grip. You get almost effortless access to your frequently-used abilities, macros, button combinations, and spells. Keep your focus on the game, and not the buttons.
Solid aluminum chassis with a soft touch surface
The strong aluminum frame is the secret to low weight, high rigidity, and optimal mass distribution. The texturized, soft-touch surfaces are designed for comfort even after extended hours of gameplay. In short... it's designed to simply feel right.
Vengeance Gaming Mouse Software
Create up to 50 profiles and share, import and export macros with the Vengeance gaming mouse software. It's a free download at corsair.com.
Quick profile selection with onboard memory
Play multiple games, with multiple character types? Store up to 6 profiles in memory on the Vengeance M90 laser gaming mouse, so you can easily save your character profiles, favorite macros and frequently used keys. Enjoy the convenience of always having your profiles and preferences even if you switch PCs.
On the fly DPI adjustment
Instantly adjust DPI for precise control when quick changes are needed between different sensitivity settings... all with the simple touch of a button.
Lift Detection
When the action is fast and furious, you are constantly moving and repositioning your mouse. The M90 includes lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
Selectable Response Time
Tune the performance for your desktop surface by choosing between four response times -- 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms).
High-mass scroll wheel
The solid metal, rubberized scroll wheel doesn't just feel great -- it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
PTFE glide pads and surface detection
The low-friction glide pads ensure swift, precise movement with low effort, and the M90 automatically optimizes its performance for your desktop surface.
Play multiple games, with multiple character types? Now you can set up your mouse performance and button configuration for each, and switch profiles directly from the mouse. Your profiles are stored in memory that's built-in to the Vengeance M90 laser gaming mouse , so you'll stay in control even when you switch PCs.
Corsair Vengeance: Designed for performance gaming
The gear that brings your gaming to the highest performance
Incredible responsiveness. Precise accuracy. Customizable, reliable controls. Intelligent design. The smallest details and the highly crafted refinements that make all the difference. Vengeance gaming peripherals aren't typical gaming devices, but elite mice, keyboards and headsets that allow you to perform at your highest level. Brought to you by Corsair -- people enthusiastic about performance gaming.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Corsair Vengeance M90 - mouse - USB
Mouse
Wired - USB
Asia, Europe
Movement Detection Technology
Laser
Buttons Qty
15
Movement Resolution
5700 dpi
Performance
30 G maximum acceleration, 2 ms response time, up to 165 inches per second, 1 ms response time, 500 reports per second, 1000 reports per second, 125 reports per second, 8 ms response time, 250 reports per second, 4 ms response time
Profile switch, polytetrafluoroethylene (PTFE) feet, soft-touch surface, on-the-fly DPI switching
1 x USB cable - integrated - 1.8 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
2 years warranty
Mouse
Asia, Europe
Input Device
Wired
USB
Laser
Buttons Qty
15
Movement Resolution
5700 dpi
Performance
1 x USB - 4 pin USB Type A
System Requirements Details
Windows XP/Vista/7 - HD 35 MB
Scroll to top
