BT.com
Wishlist
Corsair Vengeance M65 FPS Laser Gaming Mouse - 8200DPI - Arctic White
Delivery
Standard Due date unavailable
The Vengeance M65 laser mouse is a finely-honed FPS gaming tool. It offers an 8200 DPI sensor for superior tracking, a dedicated sniper button that lets you switch resolution for extremely accurate shots, and an adjustable weight system for a custom fit to the way you play.
Highly Accurate Tracking
If you're good at gaming, you're probably playing against opponents who are just as good. M65 provides the reliable response you need to give you a competitive edge.
Advanced Customization and Control
Because winning isn't just about reflexes and accuracy - you need quick weapon selection and the ability to set up your mouse to do exactly what you need it to do.
Comfortable for Hours of Game Play
Carefully selected materials and superior ergonomics, combined with precise tracking and advanced customization, help M65 cross that point where it doesn't feel like a mouse, but like an extension of your hand.
8200 DPI Laser Sensor
Precise tracking for highly accurate control.
Dedicated Programmable Sniper Button
Quickly switch sensor resolution when you need extreme accuracy in FPS games. It's not just for when you've selected a long-range weapon - it's an indispensible feature any time you need to quickly switch to ultra-precise control.
Second-Generation Control Panel
The control panel software (available as a free download) makes setup and customization easier than ever.
Corsair Vengeance: Designed for performance gaming
Onboard Profile Storage
Once you've set up your button configuration and other parameters for each of your favorite games, you can quickly toggle between profiles directly from the M65. Since they're stored onboard, you can take your profiles with you.
Aluminum Unibody Design
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Adjustable Weight System
Three adjustable tuning zones allow you to customize the weight of your M65 to give it just the exact feel you want.
Selectable Response Time
Tune the performance for your desktop surface by choosing between 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms).
High-Mass Scroll Wheel
The solid metal, rubberized scroll wheel doesn't just feel great -- it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
Switches Rated for 20 Million Clicks
The durable you need for years of high-performance gaming.
Soft-Touch Materials
Surfaces are textured and have just the right amount of give for outstanding comfort.
PTFE Glide Pads
M65 is designed with low-friction contact points for swift, precise movement with minimal effort.
Corsair Vengeance M65 FPS Gaming - mouse - USB - arctic white
Mouse
Wired - USB
Arctic white
Europe
Movement Detection Technology
Laser
Buttons Qty
8
Movement Resolution
8200 dpi
Performance
2 ms response time, 1 ms response time, 500 reports per second, 1000 reports per second, 125 reports per second, 8 ms response time, 250 reports per second, 4 ms response time
Programmable buttons, Profile switch, adjustable weight, polytetrafluoroethylene (PTFE) feet, soft-touch surface, sniper button, rubberised scroll wheel
1 x USB cable - integrated
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
2 years warranty
Mouse
Arctic white
Europe
Input Device
Wired
USB
Laser
Buttons Qty
8
Movement Resolution
8200 dpi
Performance
1 x USB - 4 pin USB Type A
Software Included
Drivers & Utilities
2 years warranty
Service & Support Details
Scroll to top
