BT.com
Wishlist
Corsair Vengeance M60 Performance FPS Gaming Mouse
Delivery
Standard Due date unavailable
The Vengeance M60 is an enthusiast-grade laser gaming mouse with premium responsiveness, FPS-optimized design, and superior control
Superior ergonomics and a dedicated sniper button will make the M60 laser gaming mouse your favorite weapon of mass destruction. It's functional design and soft-touch surfaces are comfortable in your hand, even for extended hours gaming sessions. The dedicated sniper button automatically lowers your DPI so that you can quickly adjust your aiming precision and precisely locate shots.
Enthusiast-grade 5700 DPI laser sensor
You get maximum precision and response from the Avago Technologies ADNS-9500 LaserStream™ Gaming Sensor, even on high resolution displays. Outpace and dominate opposing players with less accurate or slower gaming mice.
Optimized for First-Person Shooters -- Ergonomic design with a dedicated sniper button
Unibody aluminum structure with adjustable weight tuning
A unibody aluminum frame is the secret behind the M60's low weight, high rigidity, and optimal mass distribution. It also has three adjustable tuning zones, allowing you to customize your mouse's weight to have just the exact feel you want.
Lift Detection
When the action is fast and furious, you are constantly moving and repositioning your mouse. The M60's lift detection provides high precision tracking and reliable cursor placement even when lifted off of the mousing surface.
Selectable Response Time
Tune the performance for your desktop surface by choosing between four response times -- 1000Hz, 500Hz, 250Hz, or 125Hz (1ms, 2ms, 4ms or 8ms).
High-mass scroll wheel
The solid metal, rubberized scroll wheel doesn't just feel great -- it gives you the precision you need when selecting weapons. Precise tactile feedback and accuracy help make sure that you select the right weapon every time.
PTFE glide pads and surface detection
The low-friction glide pads ensure swift, precise movement with low effort, and the Vengeance M60 laser gaming mouse automatically optimizes its performance for your desktop surface.
Corsair Vengeance: Designed for performance gaming
The gear that brings your gaming to the highest performance
Incredible responsiveness. Precise accuracy. Customizable, reliable controls. Intelligent design. The smallest details and the highly crafted refinements that make all the difference. Vengeance gaming peripherals aren't typical gaming devices, but elite mice, keyboards and headsets that allow you to perform at your highest level. Brought to you by Corsair -- people enthusiastic about performance gaming.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Corsair Vengeance M60 - mouse - USB
Mouse
Wired - USB
Asia, Europe
Movement Detection Technology
Laser
Buttons Qty
8
Movement Resolution
5700 dpi
Performance
30 G maximum acceleration, 2 ms response time, up to 165 inches per second, 1 ms response time, 500 reports per second, 1000 reports per second, 125 reports per second, 8 ms response time, 250 reports per second, 4 ms response time
Adjustable weight, polytetrafluoroethylene (PTFE) feet, golden USB plug, soft-touch surface, sniper button
1 x USB cable - integrated - 1.8 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
2 years warranty
Mouse
Asia, Europe
Input Device
Wired
USB
Laser
Buttons Qty
8
Movement Resolution
5700 dpi
Performance
1 x USB - 4 pin USB Type A
Software Included
Drivers & Utilities
Scroll to top
