BT.com
Wishlist
Corsair Vengeance K70 Gaming Keyboard - Gunmetal - Cherry MX Brown
Delivery
Standard Due date unavailable
Corsair Vengeance K70 Cherry MX Brown Mechanical Gaming Keyboard
Mechanical performance and brilliant per key backlighting in a rugged brushed aluminum design
The Corsair K70 is a fully mechanical, backlit keyboard that's designed for performance gaming. The built-in Cherry MX Brown switches deliver fast and precise response with light tactile feedback for comfortable typing. Every key is individually lit for brilliant backlighting and easy customizability to highlight important functions. The black anodized brushed aluminum structure provides rugged durability and a professional-grade finish. Replaceable contoured keycaps make it easier to find critical WASD keys--even in dim light. Plus the 20 Key Roll-over and 100% Anti-Ghosting mean that every key you touch translates directly into the game.
Product Features
- Cherry MX Brown Mechanical Switches - Fast and precise response with light tactile feedback for comfortable typing.
- Key-by-Key Customizable Backlighting - Brilliant blue LEDs with adjustable brightness and per key programmability to light up just the keys you need. Save the combination for your favorite game directly to the keyboard.
- Contoured, Textured WASD Keycaps - Keep your eyes on the action with easy to locate FPS keys
- Anodized Gunmetal Brushed Aluminum Chassis - Professional-Grade look and feel plus the rugged durability needed for hours of gaming
- Full Key Matrix Anti-Ghosting with 20-Key Rollover - Every keystroke translates into accurate gameplay--even when multiple keys are pressed.
- Detachable full length wrist rest - Soft touch design that's comfortable for hours of play and easy to remove if it's in your way.
Cherry MX Brown mechanical switches
45g Actuation Force with 55g peak force
2mm to actuation and 4mm to bottom
Rated to 50 million operations
Gold contacts
Replaceable contoured, textured WASD Keycaps
Additional keys for WASD and 1-6 number keys
Up to 1000 Hz USB report rate
Selectable 8ms, 4ms, 2ms, 1ms and BIOS mode
Brilliant blue LED backlighting with key-by-key programmability to light up individual keys
468nm blue LEDs
Aluminum unibody construction for increased strength, durability and rigidity
Six dedicated multimedia keys
STOP, PREVIOUS, PLAY/PAUSE, NEXT, MUTE, VOLUME UP/DOWN roller
Windows Lock key for uninterrupted game play
Product Dimensions: 438 x 166mm
Product Weight: 1200g
Package Contents
Corsair Vengeance K70 mechanical gaming keyboard
Contoured WASD & 1-6 keycaps
Quick start guide
Corsair Vengeance K70 Fully Mechanical Gaming - keyboard - English - United Kingdom
Keyboard
Backlit
USB
Layout
Hot Keys Function
Volume, play/pause, stop, previous track, next track
Numeric Keypad
Gunmetal grey anodised aluminium
1.2 kg
2 years warranty
Keyboard
Backlit
USB
Input Device
Hot Keys Function
Layout
Keyboard Technology
Mechanical
Key Switch Type
Palm Rest
Numeric keypad
1.2 kg
Microsoft Windows Vista / XP / 7 / 8
Scroll to top
