BT.com
Wishlist
Corsair Vengeance K60 Performance FPS Gaming Keyboard
Free delivery
Delivery
Standard Due date unavailable
The Vengeance K60 Gaming Keyboard: designed for performance gaming.
The professional-grade brushed aluminum chassis is visually stunning, and built for durability.
Cherry MX Red mechanical key switches
Cherry® MX Red key switches are the best of the best — they provide the sensitivity and low operating force that professional gamers love. Reaction times are ulra-fast and responsive for quicker double and triple taps. The action is predictable and linear unlike lesser gaming keyboards that have a tactile bump or the annoying click of a typist’s keyboard.
Contoured, textured WASD and 1-6 Keycaps
The Vengeance K60 is designed to give you complete control even during the most intense action. The contoured, textured WASD and #1-6 keys are soft to the touch and without slip so you can focus on the game without needing to look down to find the right controls. An extra set of standard typing keycaps and a keycap replacement tool are provided for general typing.
Full key matrix anti-ghosting
Our expertly designed anti-ghosting technology provides flawless control even when you're pressing multiple keys at once.  The K60 has individual switches with dedicated diodes for each switch so every key press results in an input and is 100% ghost free without tradeoff or compromise.
20-key rollover (20KRO) on USB
Typical USB gaming keyboards are limited to the USB standard six-key rollover. The K60 features increased performance with a 20-key rollover implementation on USB at a blazing fast 1ms (1000 reports per second) reporting rate.
Professional-grade brushed aluminum chassis
The stiff-suspension chassis employs a comfortable yet rugged design that's ideal for single player or LAN party gaming, and provides durability and stability that's better than keyboards made primarily from plastic.
The K60's Cherry MX Red key switches provide the sensitivity and low operating force that professional gamers love.
Ergonomic wrist rest
The ergonomic soft-touch wrist rest helps you play for hours without fatigue. It even doubles as a safe and secure holder for the included spare set of WASD and #1-6 keycaps.
Easy access multimedia controls
Control all of your music with the easy access media controls.
USB pass-through
A USB port on the back of the Vengeance K60 gaming keyboard makes connecting your mouse or other USB devices a simple task.
Corsair Vengeance: Designed for performance gaming
The gear that brings your gaming to the highest performance
Incredible responsiveness. Precise accuracy. Customizable, reliable controls. Intelligent design. The smallest details and the highly crafted refinements that make all the difference. Vengeance gaming peripherals aren't typical gaming devices, but elite mice, keyboards and headsets that allow you to perform at your highest level. Brought to you by Corsair — people enthusiastic about performance gaming.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Corsair Vengeance K60 Performance FPS Mechanical Gaming - keyboard - English - United Kingdom
Keyboard
USB
Layout
Hot Keys Qty
6
Hot Keys Function
Volume, mute, play/pause, stop, previous track, next track
Integrated USB Hub, detachable wrist rest, tilt legs, anti-ghosting, laser engraved printing keys, gold-plated connector, 20-key rollover, Cherry MX Red technology, Windows Lock key, selectable report rate
Brushed aluminum
1.24 kg
Microsoft Certification
Compatible with Windows 7
2 years warranty
Keyboard
USB
Input Device
Hot Keys Qty
6
Hot Keys Function
Layout
Keyboard Technology
Mechanical
1.24 kg
Brushed aluminum
Key removal tool, 10 additional sculpted FPS keys
1 x USB cable - 2 m
Microsoft Windows Vista / XP / 7
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent Keyboard!
Reviewed by Luke on 14/08/2012
Being a frequent gamer and the need for fast typing, this keyboard really works for me. I prefer using the ‘cherry red’ mechanical keys much more to the ‘cherry blue’ ones used in other mechanical keyboards; they are much easier to press, quieter due to no ‘clicking’ sound and have a better feel in general.
The keyboard comes with a hand rest which is very comfortable for my wrist and within the hand rest is a removal key and 10 keys inside, numbers 1-6 and W, A, S, D can be changed with the same keys but with an almost rubber padding which enhances finger grip and is also designed to arch towards your fingers position; greatly increasing access to these keys.
The LED lights on the keyboard stand out very well for the CAPS, SCROLL and NUM lock indicators and it also has media controls built into the keyboard for muting, volume control, play/stop and skipping tracks.
Scroll to top
