BT.com
Wishlist
Corsair Vengeance C70 PC Gaming Case Arctic White
Delivery
Standard 1-3 working days
When it's time to take your competitive gaming on the road, the Vengeance C70 mid-tower PC case is a great choice. It's crafted out of solid steel and made to survive trips with less wear and tear, and the ergonomic carry handles help you move your gear with confidence.
High-performance gaming hardware requires high-performance cooling. Vengeance C70 is equipped with three 120 mm fans out of the box, with mounting points for seven more to meet your exact air cooling demands.
Easy access side panels come off with quick-release latches. The optical drive bays and 3.5" hard drive bays are tool-free. Thumbscrews secure your graphics cards, and the hard drive cages can be easily removed for better airflow or additional expansion room. Cable routing tie-downs and built-in clamps keep your system tidy.
The Vengeance C70 has convenient built-in carry handles and a steel front panel instead of plastic for enhanced durability. With up to 10 fan mounts, it also cools just about anything you can think of. Eight PCI-E slots give you the freedom for the multi-GPU setup of your dreams, and dual USB 3.0 I/O ports and six SSD-ready hard drive bays (in two removable drive cages) assure your system will be ready to compete, performance-wise. The C70 isn't just a great air-cooling case, it also features room for the H100 or other 240mm radiators on top, and if you remove the bottom hard drive cage, you can install a second 240mm radiator, ideal for dual-loop solutions. The C70 is the case you've been waiting for.
Battle-Ready, When it's time to take your competitive gaming on the road, the Vengeance C70 mid-tower PC case is a great choice. It's crafted out of solid steel and made to survive trips with less wear and tear, and the ergonomic carry handles help you move your gear with confidence.
Product Features
  • Built-in carry handles for portability.
  • Steel front panel for enhanced durability.
  • Up to 10 fan mount locations provide a ton of cooling flexibility.
  • Room for two 240mm radiators for watercooling enthusiasts.
  • Two USB 3.0 ports and headphone/mic on the front panel.
  • Quick, easy-access latches for easy side panel removal.
  • Cable routing holes with rubber grommets to keep everything clean and uncluttered.
  • Built-in cable securing latches to keep the cables behind the motherboard tray in-check.
  • Six SSD-ready hard drive trays, in two removable cages.
  • Three included 120mm fans, two intake and one exhaust.
  • CPU backplate cutout makes it easy to swap out your CPU cooler without removing the motherboard.
  • Eight PCI-E slots for multi-GPU expansion.
  • One front and dual bottom dust filters to keep your case interior clean.
  • Three tool-free optical drive bays.
  • Side panel window with dual 120mm/140mm fan mounts
  • Included USB 3.0 to USB 2.0 internal adapter for legacy support.
  • Dimensions: 501mm (H) x 232mm (W) x 533mm (L)
  • Material: Steel
  • Color: Arctic White
  • Drive Bays: (x3) 5.25" / (x6) 3.5"/2.5" Drive Caddies
  • Cooling: (x2) 120mm Intake fans / (x1) 120mm Exhaust Fan
  • Expansion Slots: 8
  • Motherboard: ATX, mATX
  • Front I/O: (x2) USB 3.0, (x1) Headphone, (x1) Mic
  • Power Supply: ATX (not included)
Box Contents
  • Corsair Vengeance Series C70 Case
  • Accessory kit
  • Quick Start Guide
Corsair Vengeance C70 - mid tower - ATX
System cabinet
Mid tower
Arctic white
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Screwless drive bays, removable dust filter, removable HDD rack, cable management holes, liquid cooling holes
No power supply
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
Internal Bays Qty
6
Front Accessible Bays Qty
3
Arctic white
Cooling System
120 mm fan x 3 , Fan mount x 7
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
8 x Expansion Slot
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Resources
The following resources are available for the Corsair Vengeance C70 PC Gaming Case Arctic White
Scroll to top
