BT.com
Wishlist
Corsair Vengeance 2000 Wireless 7.1 Gaming Headset
Delivery
Standard Due date unavailable
Corsair Vengeance™ 2000 delivers the clutter-free freedom of wireless, Dolby 7.1 surround sound technology, superior audio fidelity, and a comfortable design. Experience true wireless freedom with up to 40 feet of range and 10 hours of battery life. Dolby surround provides precise positional audio cues for an incredibly immersive gaming experience. Large 50mm audio drivers have been painstakingly tuned for tight bass response – so lows are greatly enhanced without being distorted. Noise-cancelling mic prevents background sounds from interfering with VOIP chat. Large, sound-isolating circumaural earcups have microfiber-covered memory foam earpads. Padded headband stays comfortable over long play sessions.
Free Yourself
Enjoy high-performance gaming audio without worrying about wires. With a battery life of up to 10 hours and a range of up to 40 feet, you won't miss out on any of the action.
Know your enemy
Corsair's optimized HRTF positional audio technology gives you the tactical advantage you need for victory.
7.1 Dolby Digital USB sound processing
Experience immersive multi-channel gaming the way it was intended
Hear it all
Large 50mm drivers deliver audio with more detail and more realism for maximum enjoyment and a competitive edge. The tight bass response lets you experience deep, satisfying lows without distortion or overload, and voices are crisp and clear.
Large, meticulously-tuned 50mm drivers and circumaural earcup design give you renowned Corsair audio quality with excellent sound isolation.
Take Command
Whether you're calling out DPS targets or just chatting between matches over VOIP, the unidirectional, noise cancelling condenser microphone ensures that you're heard loud and clear. The adjustable, rotating boom flips out of the way when you don't need it.
Play for Hours
The microfiber-covered memory foam earpads and padded headband let you play in comfort for hours. And if you manage to run the 10-hour battery all the way to zero, you can use the Vengeance 2000 even while it's charging.
Corsair audio: a sound philosophy
Comfort, fidelity, and playing to win
At Corsair, we believe that you need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what's on your head. You need fidelity that gives you a listening experience that's not just immersive — it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Attach the wireless adapter directly to an available USB port. Or, use the included USB extension cable for easier access.
Package contents
Corsair Vengeance 2000 wireless Gaming Headset
Dongle (wireless USB adapter)
1.5m USB extension cable
1.5m USB charging cable
Quick Start Guide
Safety Leaflet
Warranty Card
Headphones:
Frequency Response: 20Hz to 20kHz
Impedance: 32 Ohms @ 1kHz
Sensitivity: 105dB (+/-3dB)
Drivers: 50mm
USB power consumption: 500mA
Connector: USB Type A
Wireless range: up to 40 feet (12m)
Battery life: Up to 10 hours
Microphone:
Type: Unidirectional noise-cancelling condenser with adjustable, rotating boom
Impedance: 2.2k Ohms
Frequency Response: 100Hz to 10kHz
Sensitivity: -37dB (+/-3dB)
System requirements
PC with USB port
Windows® 7, Windows Vista®, or Windows XP
Internet connection (for software download)
Corsair Vengeance 2000 Wireless 7.1 Gaming Headset - headset
Headset - wireless - 2.4 GHz
Europe
Headphones Form Factor
Full size
Wireless - 2.4 GHz radio frequency
Radio Frequency Range
2.4GHz
Sound Output Mode
7.1 channel surround
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
Microsoft Certification
Compatible with Windows 7
2 years warranty
Headset - 2.4 GHz
18.3 cm
9.7 cm
20.5 cm
350 g
Europe
Headphones
Circumaural
Available Microphone
Sound Output Mode
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Dynamic Range
105 dB
Diaphragm
50 mm
Microphone
Boom
Uni-directional
Sensitivity
37 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Wireless Link
2.4GHz
Transmission Range
12 m
Connector Type
USB ( 4 PIN USB Type A )
USB charge cable - 1.5 m , USB extension cable - 1.5 m
Wireless adapter
Headphone battery
Run Time (Up To)
10 hours
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
3* Good sound, but breakable
Reviewed by Will on 20/06/2013
Although the sound quality is good, the microphone is clear, and I could wear these comfortably for hours, the plastic construction is a problem. After just two and a half months, cracks started to appear, and eventually the headphones became unusable.
Also, when I first got them, which was six months after release (to my knowledge), there was a significant bug whereby installing the software for use with them would cause them to stop working with USB 3.0 entirely. I don't know if this has been fixed - I've been using them with USB 2.0, and no longer care since I'm returning them.
I've given it three stars instead of 1 because this product would probably be suitable for people with smaller heads that don't put as much of a strain on the band, and its sound *is* very good, especially for the price.
Scroll to top
