BT.com
Wishlist
Corsair Vengeance 1400 Gaming Headset
Delivery
Standard 3-5 working days
Superior gaming audio in a comfortable design that's a perfect match for your high-end sound card
The Corsair Vengeance 1400 delivers high performance gaming audio that's a perfect match for your high-end sound card. Large 50mm drivers offer better bass response and crisp, clear midrange sound and the noise cancelling microphone lets you be heard loud and clear. The closed-back, circumaural earcups reduce environmental noise for a more immersive gaming experience. Plus the large earcups feature microfiber-covered memory foam earpads for hours of comfortable gameplay. And the Corsair Vengeance 1400 uses standard 3.5mm connectors, for compatibility with virtually all PCs and Macs.
- Large 50mm drivers - Better bass response and crisp, clear midrange for more audio quality and a competitive edge.
- Designed for comfort - Microfiber-covered memory foam earpads and a padded headband let you play longer
- Noise cancelling microphone - Be heard loud and clear, whether you're playing or just chatting between matches.
- Large diameter, circumaural earcups - Blocks distracting sounds and keeps your head in the game.
- Compact, inline remote - Easy access to headphone volume controls and microphone mute.
- Standard Dual 3.5mm Connectors - Compatible with virtually all PCs and Macs.
Headphones
- Frequency Response: 20Hz - 20 kHz
- Impedance: 32 Ohms @ 1 kHz
- Drivers: 50mm
- Connector: Dual 3.5mm Jacks
Microphone
- Type: Unidirectional noise cancelling
- Impedance: 2.2k Ohms
- Frequency Response: 100Hz - 10kHz
- Sensitivity: -41 dB (± 3 dB)
Cable Length
- 9.8 ft / 3m
Warranty
2 Years
Corsair Vengeance 1400 Analog Gaming Headset - headset
Headset - wired
Europe
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Boom
2 years warranty
Headset
Europe
Headphones
Circumaural
Headphones Cup Type
Closed
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Dynamic Range
95 dB
Diaphragm
50 mm
Microphone
Boom
Sensitivity
-41 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Connector Type
Headphones ( mini-phone stereo 3.5 mm ) ¦ Microphone ( mini-phone 3.5mm )
Headset cable - 3 m
Scroll to top
