BT.com
Wishlist
Corsair Vengeance 1300 Analog Gaming Headset
Delivery
Standard Due date unavailable
The Vengeance 1300 Gaming Headset: intense, immersive sound for gamers who care about audio
Corsair Vengeance™ 1300 Analog Gaming Headset features impressive 50mm audio drivers for audiophile-quality sound, intensive gaming and critical listening. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). Large diameter, circumaural earcup design blocks distracting sounds and keeps your head in the game. Enjoy a comfortable fit from memory foam earpads that conform to the shape of your head without binding or pinching. A high-sensitivity noise cancelling mic provides for clear, chat audio. 3.5mm analog stereo inputs provide easy connection to sound cards or integrated audio solutions.
Vengeance 1300: Your sound card meets its match
If you have a high-end sound card, the Vengeance 1300 will do it justice. If your audio card has CMSS™-3D or a similar 3D audio system, you'll hear the subtle midband positional cues that you need to enjoy accurate 3D audio and play your best. Is your enemy behind you and to the left, or to the right? Are they behind a wall, or do they have you in their crosshairs? Gaming sound designers work hard to make audio sound great, and your high-end sound card and Vengeance 1300 are a great combination for making that happen.
The results of obsessive audio engineering
Amazing sound
The massive 50mm drivers greatly reduce the overloading and distortion that can occur with gaming headsets that use 40mm drivers. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). You hear more audio, more cleanly, and you get a competitive advantage.
Superior Comfort
The extra-wide, extra deep earcups don't just help things sound great -- they feel better, too. The memory foam earpads with synthetic leather covers provide a comfortable and reliable fit that conforms to the shape of your head without binding or pinching.
Intense, Immersive Gaming
The circumaural, closed-back design blocks distracting sounds and keeps your head in the game, and the extra-large inline volume and microphone control is easy to grab and use when the action heats up -- you don't need to take your eyes off the screen.
Whether you're barking instructions to your teammates or chatting with old friends, you deserve to be heard. The unidirectional, noise-cancelling microphone is tuned to capture your voice loudly and clearly, while screening out distracting background noises. And, it flips out of sight when you're not using it.
Corsair audio: a sound philosophy
Comfort, fidelity, and playing to win
At Corsair, we believe that you need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what's on your head. You need fidelity that gives you a listening experience that's not just immersive -- it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
The Corsair Advantage
With a long history of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Corsair Vengeance 1300 Analog Gaming Headset - headset
Headset - wired
Headphones Form Factor
Full size
Wired
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Boom
Controls
Volume, microphone on/mute
2 years warranty
Headset
Headphones
Circumaural
Wired
Available Microphone
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Dynamic Range
95 dB
Diaphragm
50 mm
In-Cord Volume Control
Microphone
Boom
Sensitivity
41 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Remote Control
Controls
Connector Type
Headphones ( mini-phone stereo 3.5 mm ) , Microphone ( mini-phone 3.5mm )
Headset cable - 3 m
2 years warranty
Service & Support Details
Scroll to top
