Click to visit BT.com
BT.com
Wishlist
Corsair Raptor M40 Gaming Mouse
Quicklinx: 8QCNWS00
Mfr#: CH-9000041-EU
Programmable optical gaming mouse with adjustable weight system
Corsair Raptor M40 is designed for gaming performance. A powerful gaming-tuned optical sensor, fast response time, extra-large PTFE glide pads, and a high-mass scroll wheel put you in command. Customize it to your play style with the adjustable weight system, and seven programmable buttons put macros and other critical gaming functions just a click away.
Instant DPI switching lets you toggle between high sensor resolution for fast motion, and low resolution for super-accurate aiming. And since serious gamers play for hours at a time, the M40 has a comfortable right-handed design with textured and soft-touch surfaces.
Adjustable Weight System
Three adjustable tuning zones allow you to customize the mouse weight and balance for your playing style.
FPS-Optimized Gaming Sensor
The Avago ADNS-3090 4000 DPI optical sensor delivers outstanding precision.
Control Panel Software
Customize your gaming experience even further with power software that lets you assign keystrokes to mouse buttons, create and assign complex macros, adjust the default DPI values, and more.
Seven Programmable Buttons
Assign critical game functions to the M40 for faster response and control.
Onboard Profile Storage
Save macros and programmable buttons directly to the M40 and take them with you when you play on other PCs.
Extra-Large PTFE Glide Pads
Low friction with more contact surface area feels better and provides better control.
1000Hz Response Time
With the ability to respond to the slightest hand movement a thousand times a second, the M40 can keep up with the fastest players.
High-Mass Scroll Wheel
Delivers a precision feel for weapon selection and jumping.
Instant DPI switching with indicator LED
Quickly adjust sensor resolution when you bounce between applications and games, and select the optimal sensitivity for each weapon.
Comfortable for hours of gaming
The right-handed design has a soft-touch finish and a low-friction braided cable.
About Corsair Gaming Mice
Corsair gaming mice are precision tools, with key features like adjustable DPI, intelligent ergonomics, and configurable weight systems that let you play your best... whether you're gaming professionally, or just playing to win.
Corsair Raptor M40 Gaming - mouse
Mouse
Wired - USB
Orientation
Right-handed
7.2 cm x 11.8 cm x 3.9 cm
150 g
Europe
Movement Detection Technology
Optical
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 800/1600/3200/4000 dpi, 125/250/500/1000 reports per second
Programmable buttons, scrolling wheel, adjustable weight, polytetrafluoroethylene (PTFE) feet, soft-touch surface, braided cable, on-the-fly DPI switching with LED light indicator
1 x USB cable - integrated - 1.8 m
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
2 years warranty
Mouse
Orientation
Right-handed
7.2 cm
11.8 cm
3.9 cm
150 g
Europe
Input Device
Wired
USB
Optical
Buttons Qty
7
Movement Resolution
4000 dpi
Performance
2 years warranty
Service & Support Details
