Click to visit BT.com
BT.com
Wishlist
Corsair Raptor M30 Gaming Mouse
Quicklinx: 8QCMWS00
Mfr#: CH-9000042-EU
Optical precision for FPS gaming
Corsair Raptor M30 is designed for FPS performance, with an FPS-optimized 4000 DPI optical gaming sensor, extra-large PTFE glide pads, and fast response time for superior control and deadly accuracy. With six buttons, you can set up one-click access to critical game functions, and on-the-fly DPI switching with a DPI LED indicator lets you instantly switch to a lower sensor resolution for better long-range weapon accuracy.
FPS-Optimized Gaming Sensor
The Avago ADNS-3090 4000 DPI optical sensor delivers outstanding precision.
Extra-Large PTFE Glide Pads
Low friction with more contact surface area feels better and provides better control.
1000Hz Response Time
With the ability to respond to the slightest hand movement a thousand times a second, the M30 can keep up with the fastest players.
Instant DPI switching with indicator LED
Quickly adjust sensor resolution when you bounce between applications and games, and select the optimal sensitivity for each weapon.
Comfortable for hours of gaming
The right-handed design has a soft-touch finish, a rubber thumb grip, and a low-friction braided cable.
About Corsair Gaming Mice
Corsair gaming mice are precision tools, with key features like adjustable DPI, intelligent ergonomics, and configurable weight systems that let you play your best... whether you're gaming professionally, or just playing to win.
Corsair Raptor M30 Gaming - mouse - USB
Mouse
Wired - USB
Orientation
Right-handed
7 cm x 13 cm x 4.5 cm
156 g
Europe
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
4000 dpi
Performance
1000 reports per second, 20 G maximum acceleration, 60 inches per second, realtime sensitivity switching 800/1600/3200/4000 dpi
Programmable buttons, scrolling wheel, polytetrafluoroethylene (PTFE) feet, soft-touch surface, braided cable
Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
2 years warranty
Mouse
Orientation
Right-handed
7 cm
13 cm
4.5 cm
156 g
Europe
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
4000 dpi
Performance
