BT.com
Wishlist
Corsair Obsidian Series 550D Mid-Tower Silent Case Black
Delivery
Standard Due date unavailable
Corsair Obsidian Series 550D quiet mid-tower case: The strong, silent type.
The Obsidian Series™ 550D has been carefully engineered for noise reduction. The front and side panels are insulated with sound dampening material, and the hard drive trays and fans have soft silicon mounts to absorb vibration. The top and side panel vents are covered for noise reduction if you're not using them to install your own fans, and even the intakes are angled to reduce air noise.
The rigid, stamped steel and brushed aluminium case holds some remarkable technology that makes it easy to build great systems. There's built-in USB 3.0 support, and the drive trays work with 2.5" SSDs. The removable hard drive bays allow customization for extra-long graphics cards and maximizing airflow. And, the easy-access side panels come off at the touch of a button for easy upgrades or simply admiring your work.
  • Insulated, sound dampened side and front panels
  • Six tool-free hard drive trays with integral SSD support and soft silicon sound dampening
  • Four tool-free optical drive bays
  • Angled air intakes for reduced noise
  • Covered vents for noise reduction if additional fans (not included) are not installed
  • Front panel USB 3.0 connectors and audio connectors
  • Cable routing cut-outs with rubber grommets
  • Removable, reversible front panel
  • One-button side panel removal for quick access
  • Matte black interior
  • Three 120mm fans
  • Top panel is compatible with 240mm radiators for dual-radiator Hydro Series™ CPU coolers and liquid cooling systems
  • Eight expansion slots for multi-GPU compatibility
  • Dimensions: 20.9" x 8.7" x 19.5"
  • Material: Brushed aluminum with steel structure
  • Color: Black
  • Model: CC-9011015-WW
  • Drive Bays: (x4) 5.25" / (x6) 3.5"/2.5" Drive Caddies
  • Cooling: (x2) 120mm Intake fans / (x1) 120mm Exhaust Fan
  • Expansion Slots: 8
  • Motherboard: ATX, mATX
  • Front I/O: (x2) USB 3.0, (x1) IEEE 1394 Firewire, (x1) Headphone, (x1) Mic
  • Power Supply: ATX (not included)
  • Warranty: Two Years
Box Contents
  • Corsair Obsidian Series 550D case
  • Accessory kit
  • Quick Start Guide
Corsair Obsidian Series 550D - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Screwless drive bays, front panel door
No power supply
Specification Compliance
ATX
22.1 cm x 53.1 cm x 49.5 cm
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX
Internal Bays Qty
6
Cooling System
120 mm fan x 3 , 120/140 mm fan mount x 6 , 120 mm fan mount x 4 , 200 mm fan mount x 1
Expansion Bays
4 (total) / 4 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 3.5"
Expansion Slots
8 x Expansion Slot
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
22.1 cm
53.1 cm
49.5 cm
Resources
The following resources are available for the Corsair Obsidian Series 550D Mid-Tower Silent Case Black
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Solid reliable affair
Reviewed by Patrick McGarvey on 17/07/2013
To start from the beginning: impressive case, attractive and well organised inside. Installation of components couldn't be easier-hard drive bays beautifully easy to use with no screws, CD drive slots in nicely (again screwless). As someone self building one would hope you know what you're doing yet still the total lack of instructions was probably a bit of a bad move. Integrated 2.5" hard drive support? I would like to know how without sitting down with the several bags of little bolts and screws and trying to attach them to the hard drive bays...
That aside the case is wonderful in use and the dust filters work a dream. Not quite as deadly silent as implied, but you can see the effort has been made and if you can put out the extra pennies to buy silent components you can expect near silence.
Overall-very good, strong case with secure and simple to use components and features. Would like to see it for a few pennies less and a little more help-but what is playing around for?
Scroll to top
