BT.com
Wishlist
Corsair Obsidian Series 350D Windowed Performance Micro ATX Case
Delivery
Standard Due date unavailable
The Obsidian Series 350D Micro ATX PC case is designed for building compact high-performance systems with Micro ATX and Mini ITX motherboards. The compact size is ideal if space is limited, but there's plenty of room inside for liquid CPU cooling, dual hard drives, dual SSDs, and dual full-length graphics cards.
Like all Obsidian cases, the 350D is designed for fast and neat builds, with tool-free access and drive installation. Smart features like a native 2.5" SSD cage make the most of its small size, and the cooling-focused interior has five fan mounting points, with room for two 240 mm radiators.
Corsair Obsidian Series 350D - mid tower - micro ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
microATX, Mini-ITX
System Cabinet Features
Windowed side panel, screwless drive bays, meshed top
No power supply
Specification Compliance
ATX
21 cm x 45 cm x 44 cm
6.04 kg
2 years warranty
Mid tower
Max Mainboard Size
Micro ATX
microATX, Mini-ITX
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
2
Cooling System
Front: 140 mm fan x 1 , Rear: 120 mm fan x 1 , Fan mount x 3
CPU Cooler Max Height
160 mm
Video Card Max Length
380 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
5
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
21 cm
45 cm
44 cm
6.04 kg
Resources
The following resources are available for the Corsair Obsidian Series 350D Windowed Performance Micro ATX Case
Scroll to top
