Click to visit BT.com
BT.com
Wishlist
Corsair Obsidian Series 350D Performance Micro ATX Case
Quicklinx: 8NGTWS00
Mfr#: CC-9011028-WW
The Obsidian Series 350D Micro ATX PC case is designed for building compact high-performance systems with Micro ATX and Mini ITX motherboards. The compact size is ideal if space is limited, but there's plenty of room inside for liquid CPU cooling, dual hard drives, dual SSDs, SLI/Cross Fire ready.
Like all Obsidian cases, the 350D is designed for fast and neat builds, with tool-free access and drive installation. Smart features like a native 2.5" SSD cage make the most of its small size, and the cooling-focused interior has five fan mounting points, with room for two 240mm radiators.
  • Micro ATX and Mini ITX motherboard compatible
  • Brushed Aluminum Front Panel
  • SLI / Cross Fire ready
  • Five Expansion Slots
  • Two 2.5", two 3.5", and two 5.25" tool free drive bays.
  • Modular 2.5" SSD cage
  • Front 140mm and rear 120mm cooling fans. Room for up to five fans total.
  • Direct Airflow Path from front cooling fan to GPUs.
  • Maximum ATX PSU length 180mm
  • Maximum GPU length 380mm
  • Maximum CPU Cooler Height 160mm
  • Room for two 240mm radiators (top, front)
  • Dual USB 3.0 ports
Corsair Obsidian Series 350D - mid tower - micro ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
microATX, Mini-ITX
System Cabinet Features
Screwless drive bays, meshed top
No power supply
Specification Compliance
ATX
21 cm x 45 cm x 44 cm
6 kg
2 years warranty
Mid tower
Max Mainboard Size
Micro ATX
microATX, Mini-ITX
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
2
Cooling System
Front : 140 mm fan x 1 , Rear : 120 mm fan x 1 , Fan mount x 3
CPU Cooler Max Height
160 mm
Video Card Max Length
380 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
Expansion Slots
5
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
21 cm
45 cm
44 cm
6 kg
2 years warranty
Service & Support Details
Resources
The following resources are available for the Corsair Obsidian Series 350D Performance Micro ATX Case
