Click to visit BT.com
BT.com
Wishlist
Corsair Memory Obsidian 650D Mid-Tower Black Case
5.0*
Quicklinx: 7GNWWS00
Mfr#: CC650DW-1
Quality Construction
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.
Excellent Cooling
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you're interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.
Award-Winning Features
The 650D is a member of the award-winning Obsidian Series of cases from Corsair. The Obsidian Series is more than just a name -- it means real features that can benefit even the most experienced system builder.
Corsair Obsidian Series 650D - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 2.0 , 2 x USB 3.0 , 1 x FireWire , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Screwless drive bays
No power supply
Specification Compliance
ATX
22.9 cm x 54.6 cm x 52.1 cm
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX
Internal Bays Qty
6
Front Accessible Bays Qty
4
Cooling System
200 mm fan x 2 , 120 mm fan x 1
Expansion Bays
4 (total) / 4 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 3.5"
Expansion Slots
8 x Expansion Slot
2 x USB 2.0 , 2 x USB 3.0 , 1 x FireWire - 6 pin FireWire , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
22.9 cm
54.6 cm
52.1 cm
2 years warranty
Service & Support Details
Customer reviews
Write a review for the Corsair Memory Obsidian 650D Mid-Tower Black Case here!
Excellent case
Reviewed by Nick. Review Posted 24/03/2012
This is a solid large case which looks fantastic in brushed black. My reasons for selecting include:
1) Good airflow for nvidia SLI
2) Cable management
3) SATA HDD dock in roof (behind sliding door)
4) All black with window
5) Large cooling fans in front and roof
7) Removable dust filters
6) Corsair brand
Its easy to work on this case, nice solid action on the side catches and a large window. The power switch has a solid feel to it and is backlit by white LED, the HDD light is also a white LED.
The motherboard and modular PSU were fitted in minutes with no messing about as all the fittings were in place. The hard disk and optical drive were also fitted with ease and speed. Since my PSU is modular the ability to have cable management was really good and I have no unnecessary cables floating around. The most time taken was tying cables and making them neat for cable management.
I have also fitted a 500mm blue LED strip in the roof of the case to provide a nice blue wash of light.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent Kit
Reviewed by Steve Liddle. Review Posted 08/05/2013
Excellent kit let down by poor instructions, still not sure what some wires are for, but not seem to need them. Corsair forums and youtube videos helped a lot.
LOTS of space !
Great cable management
got an SSD and sata drive, with hot swap sata on top of case.
Very quiet and large fans
Not the cheapest case, but not see the need to replace it :)
  • Overall 5*
  • Ease of use 5*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
