BT.com
Wishlist
Corsair Memory Cooling Hydro Series H80 High-Performance CPU Cooler
Delivery
Standard Due date unavailable
How To Install: Corsair Hydro Series H80 and H100 Liquid CPU Coolers
Hydro Series™ H80 High Performance Liquid CPU Cooler
The Hydro Series H80 and H100: efficient cooling, simple installation, and the power of Corsair Link Digital.
The digital fan control button allows you to select between Quiet, Performance, or Balanced modes.
Ready for Corsair Link Digital.
The H80 and H100 work great with Corsair Link, an ecosystem of hardware and software components designed to give you unprecedented control over your PC. Connect your H80 or H100 to the Corsair Link Commander (available separately) and monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles.
Control at your fingertips.
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
The Hydro Series H80: Compact and quiet.
The H80 includes a double-thick radiator and two 120mm fans. It can be installed almost anywhere you can install a standard 120mm PC case fan, and includes mounting brackets for all modern CPU sockets.
Corsair Hydro Series makes it easy to go liquid.
Easy installation, zero maintenance.
You no longer need to invest into finicky modular watercooling systems to get serious CPU cooling performance. Each Hydro Series Liquid CPU Cooler is a sealed, closed-loop system that comes pre-filled and never needs refilling. Tubing is constructed from low-evaporation FEP for a long lifespan. Even the thermal compound is pre-applied. You'll be up and running in minutes.
The latest cooling technology
Both the H80 and the H100 include a low-profile, light-weight cooling unit with a micro-channel copper cold plate and a split-flow manifold. The result of all this attention to fluid dynamics is CPU cooling that's remarkably efficient, with a total noise level that's lower than most stock CPU fans.
Package contents
  • Corsair H80 Liquid CPU Cooler
  • Two 120mm fans
  • Mounting screws for fans and radiator
  • Mounting brackets for Intel™ LGA 775/1155/1156/1136/2011 and AMD AM2/AM3
  • Quick Start Guide
Technical Specifications
  • Radiator dimensions: 120mm x 152mm x 38mm
  • Fan dimensions: 120mm x 120mm x 25mm
  • Fan speeds (+/- 10%): up to 1300 RPM (Low Noise), 2000 RPM (Balanced), and 2500 RPM (High Performance)
  • Fan airflow: 46 - 92 CFM
  • Fan dBA: 22 - 39
  • Fan static pressure: 1.6 - 7.7mm/H20
Compatibility
  • Intel LGA 775, 1155, 1156, 1366, and 2011
  • AMD sockets AM2 and AM3
  • Hydro Series H80 requires a case with a rear or top 120mm fan mount
Corsair Hydro Series H80 High Performance Liquid CPU Cooler - liquid cooling system
Liquid cooling system
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1300/2000/2500 rpm
Air Flow
46-92 cfm
Noise Level
22 - 39 dBA
5 years warranty
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1300/2000/2500 rpm
Air Flow
46-92 cfm
Noise Level
22 - 39 dBA
Limited warranty - 5 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Corsair Memory Cooling Hydro Series H80 High
Reviewed by mr U Antepli on 04/01/2012
Again OMG Corsair keeps impressing again and again l never knew they products were so quality and value for money, this cooler is running my Intel Sandy Bridge 2600 k at 4.8ghz at 40 °C and it fits perfectly into corsair case you can controll the speed of the fans thanx to its fan speed ajustment cables. l recomend to every one well worth it!!!!!!!!!!!!
4* a good but noisy equipment
Reviewed by R.Ren on 13/03/2012
H80 is good for Fractal Design XL. I have no harass during the installation. However, you should notice the difference in fans. One blows out and the other in. As a consequence, a mistake in wind direction would result in a disaster, since the air will pack out in the middle. In addition, the long crews are self curved. The performance of H80 is good which keeps my AMD 8150 cooler at 45C at 100% loading. However, there is a huge noise when the computer starts. It seems the system is checking the cooling system. I am wondering whether there is something wrong with Corsair fan reading.
4* Corsair H80 CPU Cooler
Reviewed by Trevor N on 28/09/2012
I have fitted this cooler into a Lian V1020 case with a Sabertooth Z77 Motherboard and Ivy-Bridge processor. Ensure to fit the back plate onto the motherboard before installing the motherboard to the case. The fans are marked with the air flow direction check you have them both blowing in the same direction. The screws that hold the fans to the radiator are in my mind the weak link and when fitting the two fan guards they are only just long enough and it was a concern that the thread could let go. I would strongly recommend viewing the instalation video, it is very helpful, I was not sure from the instruction sheet that the unit required both 12v connections to be used. 1. To the CPU Fan supply and the other to the 12V peripheral connector from the power supply the video cleared this as it showed both required connection. Both fans are connected to the CPU cooler.
Scroll to top
