Click to visit BT.com
BT.com
Wishlist
Corsair Memory Cooling Hydro Series H100 High-Performance CPU Cooler
4.0*
Quicklinx: 7JSNWS00
Mfr#: CWCH100
How To Install: Corsair Hydro Series H80 and H100 Liquid CPU Coolers
Hydro Series™ H100 Extreme Performance Liquid CPU Cooler
The Hydro Series H80 and H100: efficient cooling, simple installation, and the power of Corsair Link Digital. The digital fan control button allows you to select between Quiet, Performance, or Balanced modes.
Ready for Corsair Link Digital.
The H80 and H100 work great with Corsair Link, an ecosystem of hardware and software components designed to give you unprecedented control over your PC. Connect your H80 or H100 to the Corsair Link Commander (available separately) and monitor a wide range of parameters, including pump speed, coolant temperature, and fan speed, and customize your own performance profiles.
Control at your fingertips.
The low-profile integrated pump and cold plate includes push-button control so you can select the fan speed and cooling performance setup that best suits your needs. The cool white LED display lets you know at a glance which profile is being used.
The Hydro Series H100: Go long.
Want even more? Featuring a full 240mm radiator and two 120mm fans, the Corsair Hydro Series H100 extreme performance liquid CPU cooler is designed to deliver cooling performance that meets the needs of even the most demanding enthusiast.
Corsair Hydro Series makes it easy to go liquid.
Easy installation, zero maintenance.
You no longer need to invest into finicky modular watercooling systems to get serious CPU cooling performance. Each Hydro Series Liquid CPU Cooler is a sealed, closed-loop system that comes pre-filled and never needs refilling. Tubing is constructed from low-evaporation FEP for a long lifespan. Even the thermal compound is pre-applied. You'll be up and running in minutes.
The latest cooling technology.
Both the H80 and the H100 include a low-profile, light-weight cooling unit with a micro-channel copper cold plate and a split-flow manifold. The result of all this attention to fluid dynamics is CPU cooling that's remarkably efficient, with a total noise level that's lower than most stock CPU fans.
Package contents
  • Corsair H100 Liquid CPU Cooler
  • Two 120mm fans
  • Mounting screws for fans and radiator
  • Mounting brackets for Intel™ LGA 775/1155/1156/1136/2011 and AMD AM2/AM3
  • Quick Start Guide
Technical Specifications
  • Radiator dimensions: 122mm x 275mm x 27mm
  • Fan dimensions: 120mm x 120mm x 25mm
  • Fan speed: 1300 - 2600RPM
  • Fan airflow: 46 - 92 CFM
  • Fan dBA: 22 - 39 dBA
  • Fan static pressure: 1.6 - 7.7mm/H20
Compatibility
  • Intel LGA 775, 1155, 1156, 1366, and 2011
  • AMD sockets AM2 and AM3
  • Hydro Series H80 requires a case with a rear or top 120mm fan mount
  • Hydro Series H100 requires a case with dual 120mm fan mounts with 15mm spacing for a 240mm radiator
Corsair Hydro Series H100 Extreme Performance Liquid CPU Cooler - liquid cooling system
Liquid cooling system
Compatibility
LGA775 Socket, LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket
Heatsink Material
Copper with aluminium base
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1300-2500 rpm
Air Flow
46-92 cfm
Noise Level
22 - 39 dBA
27.5 cm x 2.7 cm x 12.2 cm
5 years warranty
27.5 cm
2.7 cm
12.2 cm
Heatsink & Fan
Compatible With
Heatsink Material
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1300-2500 rpm
Air Flow
46-92 cfm
Air Pressure
1.6-7.7 mm
Noise Level
22 - 39 dBA
Mounting Kit
Included
5 years warranty
Service & Support Details
Limited warranty - 5 years
Customer reviews
Write a review for the Corsair Memory Cooling Hydro Series H100 High-Performance CPU Cooler here!
Best I have
Reviewed by The lord . Review Posted 11/12/2011
I could go on about system specs etc but I have a Corsair H80 and an Antec kuler h20 so I can say with for sure that this is the top cpu cooler of its type and after using this for a couple of weeks I shall be relacing the antec with an H100 for sure maybe ever the H80.I am seeing some really amazing results just with the 2 supplied fans on a 3930k cpu and sabertooth mobo using the high speed setting on the pump(can't hear it like I can with the antec),idles at 24c and hardly goes in to the low 30c's playing BF3 in 3d, even feel chilly with this under the desk blowing air up at me.If your case can take it(the H100 is in a Corsair 650d with just the 200mm intake and 120mm rear exhaust) buy it and see for yourself you will not believe difference.First time I used BT and have to say great service ordered The H100 with cpu,mobo and memory on a friday got it well packaged Monday morning wasn't expecting it until Tues/Wednesday saved £60 over my usual supplier in the process.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
corsair h100 cpu cooler
Reviewed by ken. Review Posted 23/12/2011
haveing had this cooler for quite a while now all i can say its the best water cooling system on the market for self contained units i have the h80 as well but the h100 just as the edge i would recomend this cooler to all
  • Overall 5*
  • Ease of use 5*
Love it
Reviewed by Rampis. Review Posted 12/11/2011
Silent thing, very easy to instoll. My case Corsair Carbide Series 500R.
  • Overall 5*
  • Ease of use 5*
Pump creating a loud grinding noise
Reviewed by Sam. Review Posted 11/08/2012
Bought a few days ago. Fitted today and instantly heard a loud rattling/grinding noise coming directly from the pump. I expected good things from Corsair but this is unacceptable. I had intentions of having a quiet/silent PC setup paired with their Obsidian 550D Case but this noise is louder than all fans on 100%. Very disappointed, and I warn anyone who is thinking of buying this, you may get the same problems I'm having!
  • Overall 1*
  • Ease of use 2*
  • Value for money 1*
Corsair H100 Noisy Unit
Reviewed by James . Review Posted 18/09/2012
I bought this product for my new computer build which is powered by another corsair product (The TX 850) The cooler is very aesthetic and fits well into most cases. However I like hundreds of others am experiencing a loud rattling noise every time I start my computer which never goes away, the noise is unbearable I have tried every fix possible but the noise still consists. I have already sent the product back 3 times and every time I get one back the same happens. I would highly advise that you stay clear of this product as its not worth the hassle. As for BT they did an excellent job getting it delivered, cant complain about that.
  • Overall 1*
  • Ease of use 1*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
