BT.com
Wishlist
Corsair Hydro Series H80i GT High Performance Liquid CPU Cooler
Delivery
Standard Due date unavailable
The Hydro Series H80i GT is a high performance, all-in-one liquid CPU cooler that works with standard 120mm radiator mounts. The extra-thick 49mm x 120mm radiator and dual SP120L PWM fans provide the excellent heat dissipation you need for high performance CPUs. It's Corsair Link compatible, so you can customize cooling performance, monitor system temperature, and change the color of the RGB LED lighting.
Corsair Hydro Series CPU coolers give you the power of liquid cooling in a compact, easy-to-install package. They offer superior cooling for higher overclocking performance, without the complexity of traditional water cooling kits.
Corsair Hydro Series H80i GT High Performance Liquid CPU Cooler - liquid cooling system
Liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA2011-3 Socket
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2435 rpm
Air Flow
70.7 cfm
Noise Level
37.7 dBA
Pulse-width modulation (PWM) support
1.8 kg
Corsair Link
5 years warranty
1.8 kg
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Fans Qty
2
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2435 rpm
Air Flow
70.7 cfm
Air Pressure
4.65 mm
Noise Level
37.7 dBA
Mounting Kit
Included
Corsair Link
Limited warranty - 5 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Use your own thermal paste.
Reviewed by Megan Morse on 07/07/2015
The cooler is fantastic but use your own thermal paste. The original paste did not provide a good enough contact and the temp kept creeping up to 90 degrees even whilst idling. Once I used my own thermal paste the temp has not gone above 70 degrees even under load.
Scroll to top
