BT.com
Wishlist
Corsair Hydro Series H60 2013 High Performance Liquid CPU Cooler
Corsair Hydro Series H60 2013 High...
£70.81
£70.81
Add to wishlist
Delivery
Standard Due date unavailable
Compatible with 4th generation Intel® Core™ series processors
The Corsair Hydro Series H60 is a fantastic choice for cooling. With a micro-channel cold plate and a split-flow designed manifold, the H60 brings remarkable technologies to an affordable price point. If that weren't enough, the H60 also features a fan custom-designed to offer enhanced static pressure, which means better cooling.
Make the Move to Liquid
Upgrade from your stock CPU fan or bulky air cooler to the efficiency and simplicity of liquid CPU cooling. Enjoy better cooling performance and lower noise, and protect your investment in your CPU.
Advanced Fan Design
The included SP120L fan uses custom-engineered impellers for better static pressure to noise ratio, offering improved performance at lower noise levels.
  • New, improved SP120L fan offers lower noise and better performance
  • Improved micro-fin copper coldplate for superior heat dissipation
  • Low evaporation, large diameter tubing offers decreased resistance and improved flexibility
  • Pre-filled, never needs refilling
  • Easy install magnetic mounting bracket
  • Low-profile pump for easy installation and better airflow
  • Low-profile black aluminum heat exchanger
  • Intel® Mounting hardware for LGA 115x, 1366, and 2011
  • AMD® Mounting hardware for AM2, AM3, FM1, and FM2
Specs
  • Coldplate Material Copper Micro Fin
  • Tubing Material Wide Diameter Low Evaporation Rubber
  • Radiator Material Aluminum
  • Radiator Size 120mm x 152mm x 27mm
  • Fan(s) included (1) SP120L - 120mm x 25mm
  • Fan Max Speed 2000 RPM +/- 10%
  • Fan Airflow 54 CFM
  • Fan Static Pressure 2.36 mmH20
  • Fan Noise Level 30.85 dBA
  • Intel Mounting Hardware LGA 115x, 1366, 2011
  • AMD Mounting Hardware AM2, AM3, FM1, FM2
CORSAIR Hydro Series H60 High Performance Liquid CPU Cooler - liquid cooling system
Liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket FM1, Socket FM2, Socket AM4
Heatsink Material
Copper with aluminium base
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2000 rpm
Air Flow
54 cfm
Noise Level
30.85 dBA
570 g
Mounting magnet
5 years warranty
570 g
Heatsink & Fan
Compatible With
Heatsink Material
Heatsink Dimensions
152 mm x 120 mm x 27 mm
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2000 rpm
Air Flow
54 cfm
Air Pressure
2.36 mm
Noise Level
30.85 dBA
Mounting magnet
Limited warranty - 5 years
Resources
The following resources are available for the Corsair Hydro Series H60 2013 High Performance Liquid CPU Cooler
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great Cooler for Overclocking.
Reviewed by Davison89 on 21/08/2013
Used this instead of my stock cooler for my i5 3750K, at first I was getting around 30 idle then when I overclocked around 35, so not much difference at all.
Would recommend this to anyone very easy to install and use.
Might wan't to buy an extra fan for the radiator to do push pull config or any of your choice.
5* Just perfect
Reviewed by Jack on 30/09/2013
Cooler works perfectly keeping temp below 40C with 3D games running at high details. Fan speed below 2000 rpm. Cooler is installed on AMD FX 6300 CPU. I was afraid the pump outlets will be touching memory stick in bank 0 ( closest to processor on ASUS M5A97 LE R2.0 ) but after fitting I have 3mm space, nice. Good price in BT.com store, thank you. Recommend buying it. Regards
Scroll to top
