Click to visit BT.com
BT.com
Wishlist
Corsair Hydro Series H55 Quiet CPU Cooler
4.0*
Quicklinx: 8CXGWS00
Mfr#: CW-9060010-WW
Type: CPU Cooler
1 on order, no confirmed delivery date
£68.48
Compatible with 4th generation Intel® Core™ series processors
The easy performance upgrade for your Intel CPU Your PC will run cooler and quieter when you replace your CPU's standard heatsink with a Hydro Series H55. Installation is straightforward. If you can get to the back of your PC's motherboard, you can install an H55. All you'll need is a screwdriver. Great for smaller cases The compact components and flexible tubing make H55 easy to install even if you're cramped for space.
Product Features
  • Pre-filled, never needs refilling
  • Tool-free mounting bracket
  • Low-noise, low-speed 120mm fan
  • Flexible rubber hose for installation in tight spaces
  • Low-profile pump for easy installation and better airflow
  • Micro fin copper cold plate for superior heat dissipation
  • Low-profile black aluminum heat exchanger
  • Intel® Mounting hardware for LGA 115x, 1366, and 2011
  • AMD® Mounting hardware for AM2, AM3, and FM1
Specs
  • Coldplate Material Copper Micro Fin
  • Tubing Material Low Evaporation Rubber
  • Radiator Material Aluminum
  • Radiator Size 120mm x 152mm x 27mm
  • Fan(s) included (1) 120mm x 25mm
  • Fan Max Speed 1700 RPM +/- 10%
  • Fan Airflow 57 CFM
  • Fan Static Pressure 1.9 mm H20
  • Fan Noise Level 30.32 dBA
  • Intel Mounting Hardware LGA 115x, 1366, 2011
  • AMD Mounting Hardware AM2, AM3, FM1
Corsair Hydro Series H55 Quiet CPU Cooler - liquid cooling system
Liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1
Heatsink Material
Aluminium with copper base
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1700 rpm
Air Flow
57 cfm
Noise Level
30.32 dBA
5 years warranty
Heatsink & Fan
Compatible With
Heatsink Material
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
1700 rpm
Air Flow
57 cfm
Air Pressure
1.9 mm
Noise Level
30.32 dBA
Mounting Kit
Included
5 years warranty
Service & Support Details
Limited warranty - 5 years
Corsair Hydro Series H55 Quiet CPU Cooler Bundle deal on Corsair Hydro Series H55 Quiet CPU Cooler
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£88.01
saving £8.26
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£78.47
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£72.57
saving £0.88
Resources
The following resources are available for the Corsair Hydro Series H55 Quiet CPU Cooler
Customer reviews
Write a review for the Corsair Hydro Series H55 Quiet CPU Cooler here!
Great little cooler, better than stock fan
Reviewed by Simon Richardson. Review Posted 11/03/2014
I run with am AM3 8 core processor and under normal operation would have a CPU temp of around 40-45 degrees.
I recently ran some imaging software which hit the processor hard and caused the system to reach 70 degrees at which stage it shut down.
I replaced the stock fan for one of these units and found installation to be relatively easy but you do need to have an hour spare to give time to do it properly and tidily.
Another good thing with this particular unit (over the model H60 unit) is that the pump section which has contact with the processor is relatively small which was a major issue in my case due to the RAM modules being quite close to the processor. There is still plenty of room between the water pipes and the RAM so it is great if you are short of space.
Since installing the cooler my normal operation is around 30 degrees and when running the imaging software it has never gone over 45 degrees (which is what I was getting under normal load balance with the stock fan)!
  • Overall 4*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Type: CPU Cooler
Brand: Corsair
Price Range Inc VAT: 50 - 100
