BT.com
Wishlist
Corsair Hydro Series™ H70 CORE High Performance Liquid CPU Cooler
Delivery
Standard Due date unavailable
How To Install: Corsair Hydro Series H70 CPU Cooler Video
Hydro Series H70 CORE builds on the legacy of the original H70 cooler, with one key difference: you supply your own fans. If you've already built a high-performance PC system (or three), you probably have a few extra 120 mm fans lying around. Or, you might just want to choose your own fans. Either way, the H70 CORE gives you the freedom to fully customize your cooling performance.
The physics are simple: larger radiators have more surface area, and more surface area means more efficient heat transfer. The H70 CORE radiator is twice as thick as the standard radiator to provide excellent cooling potential.
Corsair Hydro Series H70 CORE High Performance Liquid CPU Cooler - liquid cooling system
Liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1
Heatsink Material
Copper with aluminium base
5 years warranty
Heatsink & Fan
Compatible With
Heatsink Material
Limited warranty - 5 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* good quality cooler
Reviewed by kikassridec2 on 13/06/2013
installation took 10-15 mins alil tricky at first then fitted the radiator and fan to the chassis first then attatched cooler to cpu much easier. keep cpu (3970x) to a steady 50c running 4.1ghz constant.
3* Good and Bad
Reviewed by Matthew on 06/07/2012
Great cooling potential for your cpu, i bought it for this reason. However, the installation is a pain in the arse, the bracket collapses just about all the time when attempting to put the cooling block on. So be prepared to retry more than once, maybe you will be more savvy than i.
Scroll to top
