Click to visit BT.com
BT.com
Wishlist
Corsair Hydro H110 280mm High Performance Liquid CPU Cooler
Quicklinx: 8J7JWS00
Mfr#: CW-9060014-WW
Compatible with 4th generation Intel® Core™ series processors
Extreme CPU cooling performance
Hydro Series H110 is an all-in-one liquid CPU cooler that provides cooling that's far superior to stock CPU air fans. Liquid cooling simply works better than air cooling, and the self-contained design of the H110 makes it easy for you to protect your valuable CPU.
Take advantage of your 280mm radiator mount
For efficient cooling, bigger is better - it's simple physics. If your PC's case can fit a 280mm radiator, Hydro Series H110 will give you better performance. The larger diameter fans provide better airflow with lower noise than most 120mm fans, and the 280mm radiator has more surface area for faster cooling.
  • 140mm radiator: The 140mm-wide radiator has a larger surface area than typical 120mm radiators for more efficient heat transfer.
  • Low-RPM 140mm fan: The blades of the included 140mm fan have more surface area than most 120mm fan blades, so it doesn't need to spin as fast to deliver the same airflow.
  • Next-generation tubing: The low-evaporation, easy-bend tubing is guaranteed leak-free
  • Advanced cold plate and manifold design: The cold plate uses copper for outstanding heat transfer, and the manifold is engineered for efficient flow.
  • Simple mounting bracket: The multi-platform mounting bracket easily adapts for Intel and AMD processors.
  • Radiator Dimensions: 140mm x 312mm x 29mm
  • Fan Dimensions: 140mm x 25mm
  • Fan Speed: 1500 +/- 10% RPM
  • Air Flow: 94 CFM
  • Static Pressure: 1.64mm-H2O
  • Noise Level: 35dB(A)
CPU Compatibility
  • Intel LGA 1155
  • Intel LGA 1156
  • Intel LGA 1366
  • Intel LGA 2011
  • AMD AM2
  • AMD AM3
  • AMD FM1
  • AMD FM2
Box Contents
  • Corsair Hydro Series H110 High Performance Liquid CPU Cooler
  • Mounting kit for all modern CPU sockets
  • Two 140mm High Torque Fans
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
Corsair Hydro Series H110 Extreme Performance Liquid CPU Cooler - liquid cooling system
Liquid cooling system
Package Content
Thermal paste
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2
Heatsink Material
Copper
Fans Qty
Dual
Fan Diameter
140 mm
Fan Height
25 mm
Rotation Speed
1500 rpm
Air Flow
94 cfm
Noise Level
35 dBA
5 years warranty
Package Content
Thermal paste
Heatsink & Fan
Compatible With
Heatsink Material
Copper
Heatsink Dimensions
312 mm x 140 mm x 29 mm
Fans Qty
2
Fan Diameter
140 mm
Fan Height
25 mm
Rotation Speed
1500 rpm
Air Flow
94 cfm
Air Pressure
1.64 mm
Noise Level
35 dBA
Mounting Kit
Included
5 years warranty
Service & Support Details
Limited warranty - 5 years
