BT.com
Wishlist
Corsair H80i Hydro Series Extreme Performance CPU Cooling
Delivery
Standard Due date unavailable
Compatible with 4th generation Intel® Core™ series processors
High-Performance CPU Cooling
Protect your hardware and increase your CPU's overclocking potential. Dual fans and a double-thick radiator deliver outstanding cooling efficiency.
Corsair Link Monitoring and Control
Monitor temperature and control lighting and fan speed on your screen. No additional hardware is necessary.
Custom Fan Design
The 120mm fans use wide, low-pitch blades for better static pressure to noise ratio, offering improved efficiency at lower noise levels.
Product Features
  • Double thick 120mm radiator for increased cooling and compatibility
  • Integrated Corsair Link™ functionality allows you to adjust fan speed profiles and lighting, and monitor coolant temp via the free Corsair Link Dashboard software download.
  • Two SP120L High Performance fans optimize static pressure at a reduced noise level for amazing performance.
  • Large-diameter, low permeability tubing ensures long life and improves flexibility for an easier installation.
  • A new improved micro-channel cold-plate design more efficiently transfers heat.
  • Quick and easy magnetic installation brackets make it easier than ever to upgrade to watercooling.
  • Includes mounting hardware compatible with all modern CPU socket designs
  • Radiator Dimensions: 120mm x 152mm x 38mm
  • Fan Dimensions: 120mm x 25mm (4.72 x 0.98in)
  • Fan Speed: 2700 RPM (+/- 10%)
  • Air Flow: 77 CFM
  • Static Pressure: 4 mm/H2O
  • Noise Level: 37.68 dBA
CPU Compatibility
  • Intel LGA 1155
  • Intel LGA 1156
  • Intel LGA 1366
  • Intel LGA 2011
  • Intel LGA 1150
  • AMD AM2
  • AMD AM3
  • AMD FM1
  • AMD FM2
Box Contents
  • Corsair Hydro Series H80i High Performance Liquid CPU Cooler
  • Magnetic Multi-platform mounting kit for all modern CPU sockets
  • Dual SP120L High Performance Fans
  • USB Cable for Corsair Link™ Compatibility
  • Fan and radiator mounting screws
  • Thermal compound (pre-applied)
  • Quick Start Guide
New Firmware and Corsair Link Dashboard Available to download - Important Updates included http://www.corsair.com/us/media/cms/drivers/H80i_v1.0.4.zip
CORSAIR Hydro Series H80i Extreme Performance Liquid CPU Cooler - liquid cooling system
Liquid cooling system
Compatibility
LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, LGA2011 Socket, Socket FM1, Socket FM2
Heatsink Material
Copper with aluminium base
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2700 rpm
Air Flow
77 cfm
Noise Level
37.68 dBA
1.2 kg
Mounting magnet, Corsair Link
5 years warranty
1.2 kg
Heatsink & Fan
Compatible With
Heatsink Material
Heatsink Dimensions
152 mm x 120 mm x 38 mm
Fan Diameter
120 mm
Fan Height
25 mm
Rotation Speed
2700 rpm
Air Flow
77 cfm
Air Pressure
4 mm
Noise Level
37.68 dBA
Mounting Kit
Included
Limited warranty - 5 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Sorted my overheating issues out
Reviewed by Anonymous on 04/06/2013
Purchased this after experiencing overheating issues with my old air cooler, i have been using it on my 3570K overclocked and temps are fantastic, very pleased.
3* take care
Reviewed by Anonymous on 04/01/2013
Got one of these coolers and but have problems fitting it as the ASUS mother board I have has a fan fitted to the chip set cooling heat pipe between the cpu and the case so by fitting the fans and rad where the case fan is it will stop the chip set fan so will have to fit everything outside the case
Scroll to top
