BT.com
Wishlist
Corsair Graphite Series 780T Full Tower PC Case White
Delivery
Standard Due date unavailable
The stunning Graphite Series 780T Full-Tower PC case can satisfy the most hardcore gamer or overclocker with ample room for nine drives and nearly a dozen large cooling fans. Into water cooling? You'll appreciate the generous space for dual 360mm radiators. And, you'll get everything done faster: the 780T offers easy maintenance shortcuts like tool-free removal of side panels, hard drives, and graphics cards. A three-speed fan control button and generous options for peripheral connections make the front-panel a true time saver.
CORSAIR Graphite Series 780T - full tower - XL-ATX
System cabinet
Full tower
White
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone , 2 x USB 2.0
Supported Motherboards
ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
System Cabinet Features
Screwless PCI card retainers, windowed side panel, screwless drive bays, fan speed controller with gauge, cable management holes, modular HDD brackets, supports 240 mm radiator in front panel, supports 240 mm radiator in top, supports 120 mm radiator in rear, screwless side panels, supports 280 mm radiator in top, made of steel, supports 280 mm radiator in front panel, supports 360 mm radiator in top, supports 140 mm radiator in rear, supports 360 mm radiator in front panel, supports 240 mm radiator in bottom
No power supply
Specification Compliance
ATX
33.2 cm x 68.9 cm x 67 cm
11.3 kg
2 years warranty
Full tower
Max Mainboard Size
XL-ATX
ATX
Internal Bays Qty
9
Front Accessible Bays Qty
2
Product Material
Steel, acrylic
White
Cooling System
Front: 140 mm fan x 2 / intake , Rear: 140 mm fan x 1 / exhaust , Top: fan mount x 1 / 2 x 140 mm fan or 3 x 120 mm fan supported , Bottom: fan mount x 1 / 2 x 120 mm fan supported
CPU Cooler Max Height
200 mm
Video Card Max Length
355 mm
Power Supply Max Length
260 mm
Expansion Bays
2 (total) / 2 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
9
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 2 x USB 2.0
No power supply
33.2 cm
68.9 cm
67 cm
11.3 kg
Scroll to top
