BT.com
Wishlist
Corsair Gaming VOID RGB USB Carbon 7.1 Surround Sound Gaming Headset
Clearance
Last Few Remaining
Price Drop
Price Drop!
Delivery
Standard Due date unavailable
Sound you can see
Enter the VOID -- the innovative family of advanced gaming headsets from Corsair. Whether you choose wireless, USB, or stereo powered audio gear, you will always be one step ahead of your enemies.
With fast forward design, spectacular fidelity, and innovative features like InfoMic and CUE Control, Corsair VOID gaming headsets enable you to command and control your gaming soundscape without hitting pause.
Convenient USB interface
You'll be ready to go with easy one-cable connection.
Don't pause for sound. See it with InfoMic and CUE Control.
InfoMic brings critical information to the end of your microphone, enabling an instant "heads up" for everything you need to know about in-game audio: EQ settings, Dolby, microphone mute status, and battery life - all visually communicated via the LED indicators next to the microphone.
CUE Control enables rapid re-spec of your audio settings on the fly. The digital dial and push button combo allows quick volume changes and EQ preset swaps, and toggles Dolby 7.1 on or off, all with a single control.
Unrivaled Comfort
Your ears aren't round, so why buy a headset with round earcups? Our "True Form" shape fits your ears like a glove... for your ears. And when it's time to embark on marathon gaming sessions, the microfiber-wrapped memory foam ear pads enable extended play.
RGB Lighting under your command with CUE software
Express yourself with 16.8 million color options to match your gear and your individual style. LEDs in each ear cup have fully adjustable power, pattern and color to provide anything from subtle and restrained, to eye-grabbing intensity.
The CUE (Corsair Utility Engine) enables all this, and more. And with CUE Link, your Corsair RGB gaming gear can all work in harmony, whether it's simply synchronizing your colors, or selecting wave and ripple effects that extend across your keyboard, mouse, and headset.
Epic immersion and true multi-channel audio
Efficient 50mm neodymium drivers create staggering bass, scintillating highs, and towering dynamic range, and genuine Dolby 7.1 surround delivers lethally accurate positional audio.
Noise cancelling microphone
If you're a team player, you need crystal clear voice communication. The noise-cancelling microphone puts your voice in the spotlight - and nothing else.
CORSAIR Gaming VOID Dolby 7.1 - headset
Headset - wired
Recommended Use
Computer
Europe
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 107 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Mono
Controls
Volume, microphone on/mute
2 years warranty
Headset
Earpad Material
Microfibre
Recommended Use
Computer
Europe
Headphones
Circumaural
Headphones Cup Type
Closed
Wired
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
107 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
In-Cord Volume Control
Microphone
Boom
Mono
Sensitivity
-37 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Remote Control
Controls
Connector Type
Headset (4 PIN USB Type A)
Cable
Cable Length
1.8 m
Scroll to top
