BT.com
Wishlist
Corsair Gaming H2100 Dolby 7.1 Wireless Gaming Headset GreyHawk Edition
Delivery
Standard Due date unavailable
You get 2.4GHz wireless freedom at up to 40 feet, and ten hours of uninterrupted gaming at a time. Genuine Dolby 7.1 surround gives you lethally accurate positional audio, and the 50mm neodymium drivers produce staggering bass, highs, and dynamic range. Marathon gaming sessions are easy with the microfiber-wrapped earpads, and you'll be heard loud and clear with the unidirectional noise-cancelling microphone.
Genuine Dolby 7.1 surround delivers lethally accurate positional audio. It accurately reproduces multi-channel gaming audio for precise situational awareness and the competitive edge you can only get through positional audio. It also helps reduce "headphone fatigue," which is essential if you play competitively or if you just enjoy playing for hours at a time.
Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision. They greatly reduce the overloading and distortion that can occur with gaming headsets that use smaller drivers that aren't up to the task. You'll get more accurate sound reproduction, particularly for the all-important low-frequency effects.
Corsair Gaming H2100 Dolby 7.1 Greyhawk - headset
Headset - 2.4 GHz - wireless
Recommended Use
Computer
Europe
Headphones Form Factor
Full size
Wireless
Wireless Technology
2.4 GHz radio frequency
Radio Frequency Range
2.4GHz
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 105 dB
Impedance
32 Ohm
Microphone
Boom
Microphone Technology
Condenser
2 years warranty
Headset - 2.4 GHz
Recommended Use
Computer
Max Operating Distance
12 m
Europe
Headphones
Circumaural
Wireless
Wireless Technology
Available Microphone
Frequency Response
20 - 20000 Hz
Sensitivity
105 dB
Impedance
32 Ohm
Diaphragm
50 mm
Magnet Material
Neodymium
Microphone
Boom
Condenser
Sensitivity
-37 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Wireless Link
2.4GHz
Transmission Range
12 m
Connector Type
USB (4 PIN USB Type A)
USB extension cable - 1.5 m , USB charge cable - 1.5 m
USB dongle
Headset battery rechargeable
Run Time (Up To)
10 hour(s)
Scroll to top
