BT.com
Wishlist
Corsair Gaming H2100 Dolby 7.1 Wireless Gaming Headset
Experience Cinematic Sound in Comfort
Delivery
Standard Due date unavailable
Enjoy legendary audio with zero hassle. You get 2.4GHz wireless freedom at up to 40 feet, and ten hours of uninterrupted gaming at a time. Genuine Dolby 7.1 surround gives you lethally accurate positional audio, and the 50mm neodymium drivers produce staggering bass, highs, and dynamic range. Marathon gaming sessions are easy with the microfiber-wrapped earpads, and you'll be heard loud and clear with the unidirectional noise-cancelling microphone.
  • Legendary audio, zero hassle: 2.4GHz wireless freedom up to 40ft + 10 hours of uninterrupted gaming
  • Epic immersion and true multi-channel audio: genuine Dolby 7.1 surround delivers lethally accurate positional audio
  • Unlock legendary audio: Oversized 50mm neodymium drivers bring the action to life with brilliant range and precision
  • Embark on marathon gaming sessions: comfortable microfiber-wrapped memory foam earpads enable extended play.
  • Take command: the advanced unidirectional noise-cancelling microphone makes you loud and clear
Corsair Gaming H2100 Dolby 7.1 - headset
Headset - 2.4 GHz - wireless
Europe
Headphones Form Factor
Full size
Wireless
Wireless Technology
2.4 GHz radio frequency
Radio Frequency Range
2.4GHz
Sound Effects
7.1 Channel Virtual Surround Sound
Audio Specifications
Frequency Response 20 - 20000 Hz
Impedance
32 Ohm
Microphone
Boom
Microphone Operation Mode
Uni-directional
2 years warranty
Headset - 2.4 GHz
540 g
Max Operating Distance
12 m
Europe
Headphones
Circumaural
Wireless
Wireless Technology
Available Microphone
Sound Effects
Frequency Response
20 - 20000 Hz
Impedance
32 Ohm
Dynamic Range
105 dB
Diaphragm
50 mm
Magnet Material
Neodymium
Microphone
Boom
Uni-directional
Sensitivity
-37 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional - 100 - 10000 Hz - Output Impedance 2.2 kOhm
Wireless Link
2.4GHz
Transmission Range
12 m
Connector Type
USB (4 PIN USB Type A)
USB charge cable - 1.5 m , USB extension cable - 1.5 m
Wireless adapter
Headphone battery
Run Time (Up To)
10 hours
Scroll to top
