BT.com
Wishlist
Corsair Flash Voyager USB 3.0 - USB flash drive - 32 GB - USB 3.0
Delivery
Standard Due date unavailable
USB 3.0 Speed. USB 2.0 Compatibility. Flash Voyager® Durability.
Get faster read speeds and rugged reliability with the Corsair Flash Voyager USB 3.0 flash drive. USB 3.0 read speeds let you access movies, pictures and large files up to 4x faster than traditional USB 2.0 drives and the durable rubber design is water resistant and shockproof to keep your data safe.
USB 3.0 Speed
As fast as USB flash drives are, copying files always seems to take a little longer than you'd like. The advent of the USB 3.0 interface puts an end to that. You can move files back and forth in a fraction of the time it takes with standard USB 2.0 flash drives, and the USB 3.0 interface is fast enough to allow you to view videos directly from your Flash Voyager, instead of the traditional extra step of copying them to a hard drive.
Of course, Flash Voyager USB 3.0 is backward compatible with USB 2.0. Even if you haven't yet upgraded your PC to USB 3.0, it's still a great choice for convenient, reliable portable file management, and the additional performance will be ready when your PC is.
Durable and Shock-Resistant
The finger-friendly ergonomics of the Flash Voyager USB 3.0 will make it the USB flash drive that you'll want to take with you everywhere. Reliability is essential.
Corsair's proprietary all-rubber housing is extremely durable, for worry-free transport of your valuable data. And because accidents happen, Flash Voyager USB 3.0 is water-resistant.
Unlike traditional storage media, flash drives are solid-state, so they can easily handle the everyday -- and not so everyday -- drops and bumps that come with the territory.
Convenient and Compatible
It works with Microsoft® Windows®, Mac OS X® and even Linux without drivers, and there's no software to install -- just plug it in, and go. If your computer has a USB 2.0 or USB 3.0 connector, you can use Flash Voyager USB 3.0.
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Linux, Apple MacOS X, Microsoft Windows
5 years warranty
USB flash drive
Storage Capacity
32 GB
Compatibility
Non-specific
Read Rate
Up to 80 MB/s
Write Rate
Up to 40 MB/s
Interface Type
USB 3.0
Shockproof, water resistant
Limited warranty - 5 years
74 mm
23 mm
60 g
Scroll to top
