BT.com
Wishlist
Corsair Flash Voyager Slider X2 USB 3.0 32GB
Delivery
Standard Due date unavailable
Flash Voyager Slider X2 is a compact USB 3.0 drive that doesn’t sacrifice size for performance. It has a smart design, with a USB connector that retracts for protection when you’re not using it. An activity LED tells you at a glance if it’s transferring data. It supports USB transfer speeds of up to 200 MB/s read and 90 MB/s write. The Slider X2 is backward compatible with USB 2.0, so you can use it with virtually any desktop or notebook.
Corsair Flash Voyager Slider X2 - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Linux, Apple MacOS X, Microsoft Windows
5 years warranty
USB flash drive
Storage Capacity
32 GB
Compatibility
Non-specific
Read Rate
Up to 200 MB/s
Write Rate
Up to 90 MB/s
Interface Type
USB 3.0
Retractable connector, LED access indicator
Plug and Play
Limited warranty - 5 years
54 mm
23.3 mm
11 mm
9 g
Scroll to top
