BT.com
Wishlist
Corsair Flash Voyager Mini USB 3.0 - 32GB
Corsair Flash Voyager Mini USB 3.0...
£15.92
Only 1.25” (32mm) Long! Compact Size, Full Speed USB 3.0!
25 in stock
£15.92
Add to wishlist
Delivery
Standard 3-5 working days
The tiny USB flash drive with full-size USB 3.0 performance
Flash Voyager Mini USB 3.0 is the tiny USB flash drive with full-size USB 3.0 performance. The USB 3.0 connector allows for optimal file transfer speed with the latest systems, and it's fully compatible with USB 2.0. It comes with a detachable loop for attaching to your key ring, and the durable brushed metal housing resists wear and tear.
USB 3.0 performance
It's small, but it gives you full-size speed. Enjoy optimized performance when it's connected to a USB 3.0 port.
USB 2.0 compatibility
Its works with USB 2.0 ports, too.
Compact size
At just 1.25" (32mm) long, it goes almost anywhere and you won't think about it when you're not using it.
Brushed metal housing
The sleek design protects your data and resists wear and tear. The logo is laser-etched, so it won't rub off.
Key ring convenience
The Mini comes with a rubber strap and metal loop for attaching to your key ring. You might never say "I left my USB flash drive at home" again.
USB 3.0 performance (compatible with USB 2.0)
Compact aluminium housing
Durable rubber strap and ring for convenient key-ring use
Limited 5 year warranty
Support for Microsoft Windows®, Mac OS X®, and Linux with no driver or software installation necessary
USB Standard-A connector works with both USB 3.0 and USB 2.0 ports
Corsair Flash Voyager Mini - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Linux, Apple MacOS X, Microsoft Windows
5 years warranty
USB flash drive
Storage Capacity
32 GB
Compatibility
Non-specific
Interface Type
USB 3.0
Metal body, key ring loop
5 years warranty
Service & Support Details
Limited warranty - 5 years
3.2 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great little drive
Reviewed by Terry on 30/09/2013
This is a great little USB drive, very compact compared to most others. Regarding the shipment BT please get some jiffy bags for small items, this turned up in a box you could fit a hard drive in.
4* Tiny drive, terrible packaging
Reviewed by Chris on 09/09/2013
This is an absolutely miniscule* drive with good capacity and reasonably smooth USB3 speed. Why it is shipped in a box big enough to put a pair of shoes in I do not comprehend. Shipping was faster than expected and very reasonably priced, but having to go to the post office to collect it delayed me by several days. Worth looking to see if another online retailer can offer this in packaging that frees you from frustration perhaps?
*Really, this drive is so incredibly small. About 1.5 times the length of the depth of a USB port. Mind-boggling.
Scroll to top
