BT.com
Wishlist
Corsair Flash Voyager - USB flash drive - 16 GB - USB 2.0
Delivery
Standard Due date unavailable
Corsair Flash Voyager USB drives are rugged, compact, stylish and reliable. The durable rubber design is both water resistant and virtually shockproof to keep your music, pictures, video and data safe. Plus Flash Voyager drives are fully Plug and Play and backward compatible with USB 1.1.
Durable -- Corsair's proprietary all-rubber housing is extremely durable, water resistant and drop-tested for worry-free transport of your valuable data
Shock Proof -- Solid state storage makes Flash Voyager drives virtual shock proof
Convenient -- Just plug it and go! No special cables, no power adapters needed
Compatible -- Works with Windows, Windows 7, Mac OS X and even Linux without drivers
Backed by Corsair -- A respected name with a passion for great service and support
Features:
-Durable rubber housing
-Water resistant
-Shock proof
-USB 2.0 compatible
-Plug-n-Play compatible
-Limited 10 year warranty
USB flash drive
Interface Type
USB 2.0
Storage Capacity
16 GB
Software Included
Drivers & Utilities
Microsoft Windows Millennium Edition, Apple MacOS X / MacOS 9, Linux 2.4 or later, Microsoft Windows 2000 / XP, Microsoft Windows Vista
10 years warranty
USB flash drive
Storage Capacity
16 GB
Compatibility
Non-specific
Interface Type
USB 2.0
Waterproof
Plug and Play
Software Included
Drivers & Utilities
Limited warranty - 10 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Superb turn around from Dabs
Reviewed by Rob on 04/05/2007
Ordered Thursday evening arrived Monday morning at my work address. Excellent turnaround. Product is excellent too!!
5* now good value
Reviewed by doug on 11/05/2007
This used to be way over £148.84, now £88. This needs the drivers installed to be of any use. Once fully installed great for moving 'bigger than DVD' files around. Can hold 2 DVD movies, but also perfect for holding complete Virtual Machines (eg 12gb+ files, not possible without the drivers indtalled). The rubber enclosure of the stick makes it very robust and water proof. So if work is buying its a good work horse.Come with encryption software and great for backups.
5* So what
Reviewed by Steve on 18/02/2007
What does the price in the paper catalogue have to do with reviewing this hardware?
5* Finally got mine today
Reviewed by Garry Hadlow on 08/03/2007
The product itself is good!! Ordered one 3 weeks ago when told on the site 1-3 days!! Lol.
Product is worth the money.
I've seen it a lot more expensive ones so overall quite good.
4* Ok to Good
Reviewed by retrodome on 17/01/2008
Price is ok, but not that good fit in front desktop usb ports - actually bought this and 8gb for my eee to load roms from but they won't fit together in the two usb slots due to thickness
4* Not bad
Reviewed by Anonymous on 27/12/2007
Not bad at all. But for some reason prevents my laptop from booting or waking from hibernation when it is plugged in. Its also a good looking drive and comes with an extension cable and lanyard. Downside is that the drive is a little slow on the writes. Read speed is ok though.
4* Seems Quite Good so far
Reviewed by Paul on 27/01/2010
I heard about the cap and it becoming loose. The actual stick feels robust and think it would cope next a set of keys in your pocket for example. Time will tell. I have had memory sticks which last less than 6 months. Lots of space on here means at £just over £30 its a bargain.
4* Fabulous, as long as it works
Reviewed by Ellen on 09/02/2010
I have several memory sticks from this company. Fast, reliable, value for money. So I bought another one. After one year, the usb connector bent for no apprarent reason (no extra force used to insert into port etc). I emailed BT. Was this a problem or damage? I waited. I emailed again. That ten year warranty seems like a lot of words on the packet. Corsair in the USA also seem unresponsive. It may be hit and miss but be aware: great product but if it goes wrong, you need patience and I don't know at the moment if I'll get my money back or a replacement. The system is not efficient, anyway.
3* Advertised at £148.84
Reviewed by doug on 30/01/2007
on page 27 in issue 141 of the feb07 postal catalog this is advertised at £148.84 inc Vat
Scroll to top
