BT.com
Wishlist
Corsair Flash Survivor Stealth - USB flash drive - 16 GB - USB 3.0
Delivery
Standard Due date unavailable
Military-Style data transport with USB 3.0 speed and USB 2.0 compatibility.
The special hard-anodized, aircraft-grade aluminum housing makes Flash Survivor Stealth a great choice when you’re gearing up for your next covert operation.
Built to take abuse
Your files are important — that's why you're taking them with you. Flash Survivor Stealth® USB 3.0 flash drives help keep them safe. The anodized, aircraft-grade aluminum housing is waterproof to 200 meters, vibration-resistant, and shock-resistant.
USB 3.0 Speed
If you move a lot of data, you've noticed that as convenient as USB flash drives are, they never seem to be as fast as you'd like. USB 3.0 changes the game. Flash Survivor Stealth USB 3.0 offers read speeds up to four times faster than traditional USB 2.0 drives. It's fast enough to view most videos directly from your Flash Survivor Stealth, without having to take the usual extra step of copying it to a hard drive first.
High-Performance USB 2.0 Compatibility
Not only is Flash Survivor Stealth USB 3.0 backward compatible with USB 2.0 — it offers great performance, too. No matter how up-to-date your PC is, you'll be able to quickly take care of moving your files and be off on your next adventure.
Convenient and Reliable
Universal Compatibility
It works with Microsoft® Windows®, Mac® OS X, and even Linux without drivers, and there's no software to install. Just plug it in, and go. If your computer has a USB 2.0 or 3.0 connector, you can use Flash Survivor Stealth USB 3.0.
Proven Reliability
With more than 17 years of building enthusiast-grade memory and components, we've earned a reputation for quality, compatibility, and performance. Need help? We're available by phone call, email or web forum.
Features and Performance
 Flash Survivor Stealth USB 3.0 16GBFlash Survivor Stealth USB 3.0 32GBFlash Survivor Stealth USB 3.0 64GB
SKU CMFSS3-16GB CMFSS3-32GB CMFSS3-64GB
Capacity16GB32GB64GB
Max Sequential Read Speed (USB 3.0)70 MB/s80 MB/s85 MB/s
Max Sequential Write Speed (USB 3.0)20 MB/s40 MB/s70 MB/s
InterfaceUSB 3.0USB 3.0USB 3.0
Shock1500G1500G1500G
WarrantyFive YearsFive YearsFive Years
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
Linux, Apple MacOS X, Microsoft Windows
5 years warranty
USB flash drive
Storage Capacity
16 GB
Compatibility
Non-specific
Read Rate
Up to 70 MB/s
Write Rate
Up to 20 MB/s
Interface Type
USB 3.0
Shock-proof, waterproof, vibration-proof, aluminum body
Plug and Play
5 years warranty
Service & Support Details
Limited warranty - 5 years
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Feel the quality
Reviewed by Rich on 26/02/2013
This is more expensive than flimsy plastic USB drives but you can just feel the quality. I bough t this because I was fed up with USB drives becoming unreliable after a few uses due to the connector flexing. I haven't had this for long enough to confirm that it will not suffer the same problem, but initial impressions are good, you can just feel the quality as you hold it. From the round aluminium case, with its rubber impact rings, to the solid metal construction of the stick itself, and the its firm hold upon the connector, this just sings "good quality". Even when it's not in use I just enjoy holding it. Is that wierd?
Scroll to top
