BT.com
Wishlist
Corsair Dominator Platinum 8GB Kit (2x4GB) DDR4 3466MHz 1.35V DIMM
Delivery
Standard Due date unavailable
The Dominator family of memory represents the ultimate in performance technology engineering from Corsair. The Dominator is designed to have the highest performing IC maximum over-clocking capability and efficient DHX cooling - all the while being stable and reliable.
Very few components make it into the Dominator family. Corsair performs rigorous testing and screening on all components to select only the best for the Dominator modules. The tests check for high frequency and/or low latency capabilities for each IC. Then, they are thoroughly tested for maximum interoperability and reliability as a united group to meet the stringent design criteria demanded by performance computing and gaming users.
Corsair Dominator Platinum - DDR4 - 8 GB: 2 x 4 GB - DIMM 288-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3466 MHz (PC4-27700)
Latency Timings
CL18 (18-19-19-39)
Temperature monitoring, Dual-path Heat Xchange (DHX), aluminium heat spreader, dual channel, Corsair Link connector, Corsair Dominator Platinum heatspreader, Intel Extreme Memory Profiles (XMP 2.0), white activity LED's, unbuffered
Voltage
1.35 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL18 (18-19-19-39)
Non-ECC
Voltage
1.35 V
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15-36 , Tested - 3466 MHz - 1.35 V - CL18 - 18-19-19-39
Colour Category
Black, gray
Scroll to top
