BT.com
Wishlist
Corsair DDR2 XMS2-6400 4GB kit of 2x240 pin DIMMs, Unbuffe
Delivery
Standard Due date unavailable
The TWIN2X4096-6400C4DHX is a 4096MByte matched pair of DDR2 SDRAM DIMMs built using Corsair's high performance heat sink with Dual-Path Heat Xchange (DHX) technology. This part delivers outstanding performance in dual-channel DDR2-based motherboards. It has been tested extensively in multiple DDR2 motherboards to ensure compatibility and performance at its rated speed.
Corsair XMS2 DHX - DDR2 - 4 GB : 2 x 2 GB - DIMM 240-pin
RAM memory
4 GB : 2 x 2 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz ( PC2-6400 )
Latency Timings
CL4 ( 4-4-4-12 )
Dual-path Heat Xchange (DHX) , unbuffered
Voltage
2.1 V
4 GB : 2 x 2 GB
Upgrade Type
Generic
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL4 ( 4-4-4-12 )
Non-ECC
Voltage
2.1 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
