BT.com
Wishlist
Corsair CX450M CX Series 450W Semi Modular 80 Plus Bronze ATX PSU
Delivery
Standard Due date unavailable
CX Series™ Modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, and easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series Modular quieter at idle, and reduces noise even when you’re pushing your system hard. The matte black finish, black-sleeved cables and black connectors help give your system a restrained, high-tech look.
CORSAIR CX-M Series CX450M - 2015 Edition - power supply - 450 Watt
Power supply - internal
Specification Compliance
ATX12V 2.4/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
3.27 kg
United Kingdom
Input Voltage
AC 100-240 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output connectors
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
5 years warranty
PSU Form Factor
ATX
Matte black
United Kingdom
Input Voltage
AC 100-240 V
Frequency Required
47 - 63 Hz
Output Voltage
+3.3, +5, ±12 V
Power Capacity
450 Watt
Output Current
+3.3V - 20 A , +5V - 20 A , +12V - 37.4 A , -12V - 0.8 A , +5VSB - 3 A
Modular Cable Management
80 PLUS Bronze
Cooling System
120 mm fan
Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, semi-modular
TUV, BSMI, CB, CCC, FCC, RoHS, WEEE, ICES, cTUVus, KC, China RoHS, RCM, CU-TR
Limited warranty - 5 years
15 cm
14 cm
8.6 cm
3.27 kg
Shipping Width
21.6 cm
Shipping Depth
29 cm
Shipping Height
13 cm
Shipping Weight
3.53 kg
Scroll to top
