BT.com
Wishlist
Corsair Carbide Series 500R Mid-Tower Gaming Chassis, Black
Delivery
Standard Due date unavailable
Want even more outrageous cooling flexibility? Step up to the 500R. It adds a 200 mm fan mounted on the side panel's mesh screen for extra GPU cooling, a multi-channel fan controller, and removable and relocateable hard drive cages. The ability to move and remove hard drive cages not only improves airflow - it also allows you to install graphics cards of up to 452 mm in length.
Corsair Carbide Series 500R - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x FireWire , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Screwless drive bays, removable dust filter, cable management holes
No power supply
Specification Compliance
ATX
20.6 cm x 50.8 cm x 52.1 cm
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX
Internal Bays Qty
6
Front Accessible Bays Qty
4
Cooling System
120/140 mm fan mount x 6 , 120 mm fan mount x 1 , Front: 120 mm fan x 2 , Rear: 120 mm fan x 1 , Side: 200 mm fan x 1
Expansion Bays
4 (total) / 4 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
8 x Expansion Slot
2 x USB 3.0 , 1 x FireWire - 6 pin FireWire , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
20.6 cm
50.8 cm
52.1 cm
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* nice case
Reviewed by Rob on 21/03/2012
very nice cace very happy /second case first one arrived damaged/two weeks to get the replacement
customer service was not the best but after i called them case arrived two days later
5* Amazing Case
Reviewed by Jamie on 03/05/2013
I brought this case for my £1k+ price build and im glad I did... so much room its unbelievable and space for anything you want to put in it
Scroll to top
