BT.com
Wishlist
Corsair Carbide Series 300R Windowed Gaming Case
Corsair Carbide Series 300R...
£88.77
£88.77
Add to wishlist
Delivery
Standard Due date unavailable
The Carbide Series™ 300R windowed is a compact expression of the Corsair philosophy: great systems begin with a great case. Open the easy-access side panel to find a builder-friendly design with three tool-free optical drive bays and four tool-free hard drive bays with integrated 2.5" SSD compatibility. There's room for extra-long graphics cards, and the matte black interior really shows off your gear. Finish off your build with a cable routing system that keeps wires and cables out of sight and out of the airflow path for a clean, uncluttered look.
The 300R keeps your hardware cool with amazing airflow, including a 140mm front intake fan and a 120mm rear exhaust fan. There's room to add five additional fans, including dual side-panel fan locations that can deliver cool air directly to your graphics cards. And, the dust filters are removable for easy maintenance. Features like these make the Corsair Carbide Series 300R the foundation of your next great system.
  • Oversized, tinted window with room for dual 120mm or 140mm fans
  • Room for graphics cards up to 450mm long.
  • USB 3.0 front panel connectors.
  • Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need.
  • Keep your system cool with up to 7 fan mount locations.
  • Easily accessible dust filters keep the cool air flowing over your valuable components.
  • Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout.
  • Optimize airflow and keep your system neat and tidy using the intelligent cable management system.
Corsair Carbide Series 300R - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Windowed side panel, screwless drive bays, front dust filter
No power supply
Specification Compliance
ATX
48.514 cm x 21.082 cm x 44.958 cm
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
3
Cooling System
Side: 120/140 mm fan mount x 2 , Top: 120/140 mm fan mount x 2 , Front: 120/140 mm fan mount x 2 , Front: 140 mm fan x 1 , Rear: 120 mm fan x 1 , 120 mm fan mount x 1
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7 x Expansion Slot
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
48.514 cm
21.082 cm
44.958 cm
£88.77
Save on this ideal PC Build kit!
Save £8.43
£107.99
Resources
The following resources are available for the Corsair Carbide Series 300R Windowed Gaming Case
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good quality, easy to use case...
Reviewed by Christopher on 24/09/2013
I bought this case for my first PC build. The build quality feels and looks good and strong. All the hardware I bought fitted perfectly without any issues and the design of the case allowed me to keep loose cables tidy. The fans provided are relatively quiet and the dust filter below the PSU is a handy feature. The LED's for the power button and the HDD are a bright white, which looks really nice. The only con of this case, as far as I'm concerned, is that the power button feels cheap.
4* Add 2 wish list (unsure)
Reviewed by Depressed man on 03/04/2013
Arrived today, first notice how light the case is compared to my old Zaltman GS1000plus. Feels tinny, looks good. Plain no frills, small, but not to small nicely set out inside, as described in adverts. Get to work prepare my mATX mother board for fitting. Screw 1st adapter nut onto case back plate (This is to allow the fixing of mATX to back plate.) FIT SECOND! oh, NO SECOND. So that's why it felt so light. 1 Adapter missing. Build stopped..e-mail..Corsair..stop..e-mail BT..stop..Hunt around my garage to see if I can find anything to do the job..stop..Wait a few weeks for an replacement, I hope..stopped..
Scroll to top
