BT.com
Wishlist
Corsair Carbide Series 200R Compact ATX Case
Corsair Carbide Series 200R Compact...
£59.88
The Carbide Series 200R: Designed for Easy Builds
Hurry, only 1 left in stock!
£59.88
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Tuesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Less work. More play. Build with the Carbide Series 200R and the only time you'll need to pick up a screwdriver is to install the motherboard. The side panels and expansion slots use thumbscrews, and SSD, hard drive and optical drive installation are all tool-free. Cutouts for cable routing and CPU cooling make builds and upgrades neat and simple.
Easy to Expand, and Easy to Cool
Carbide Series 200R is compact, but it's designed to let you build high-performance systems with massive storage, extra graphics performance, and superior cooling and ventilation. You get seven PCI-E slots, and you can install up to four hard drives and four SSDs at once. Eight fan mounting points let you expand your cooling system to match your high-performance components.
Easy to Use
The mid-tower form factor combines room for expandability and out-of-the-way exterior dimensions. USB 3.0, headphone and microphone ports are right up front, and the front intake dust filter helps keep the interior clean.
Smart ergonomics for easy, great-looking builds
  • Side panel thumbscrews
  • PCI-E expansion card thumbscrew mounts
  • Tool-free SSD, hard drive, and optical drive installation
  • Cutouts for cable routing and CPU cooling
Serious Expansion and Cooling Capacity
  • Seven PCI-E slots with thumbscrews and room for cards up to 430mm long (300mm with drive cage)
  • CPU coolers up to 160mm in height
  • Install up to four hard drives and four SSDs at once
  • Up to eight fan mounts (depending on hard drive configuration)
High-End Features
  • Front panel USB 3.0, headphone and microphone ports
  • Dust filters behind the front intake fan help keep the interior clean
Carbide Series 200R is compact, but it's designed to let you build high-performance systems with massive storage, extra graphics performance, and superior cooling and ventilation. The mid-tower form factor combines room for expandability and out-of-the-way exterior dimensions.
Box Contents
  • Carbide Series 200R PC case with 120mm rear exhaust and 120mm front intake fan
  • User installation guide
  • Accessories box with screws, zip ties, and other mounting hardware.
Compatibility
  • ATX and Micro ATX motherboards
  • Warranty: Two years
  • Dimension16.9 x 8.3 x 19.6 inches, or 430mm x 210mm x 497mm (H x W x L)
  • MB Support: ATX, mATX
  • Expansion Slots: 7
  • Form Factor Mid-tower
  • Material: Steel structure with molded ABS plastic accent pieces
  • Drive Bays(x3) 5.25", (x4) 3.5", (x4) 2.5"
  • Cooling(x5) 120mm/140mm fan mount locations, (x3) 120mm fan mount locations, Includes (x1) front-mounted 120mm fan and (x1) rear 120mm fan
  • Front I/O(x2) USB 3.0, (x1) Headphone, (x1) MIC, Power, Reset
  • Power SupplyATX (not included)
Corsair Carbide Series 200R - mid tower - ATX
System cabinet
Mid tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX
System Cabinet Features
Screwless drive bays, front dust filter
No power supply
Specification Compliance
ATX
21 cm x 49.7 cm x 43 cm
2 years warranty
Mid tower
Max Mainboard Size
ATX
ATX, microATX
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
3
Cooling System
120/140 mm fan mount x 5 , 120 mm fan mount x 3 , Front: 120 mm fan x 1 , Rear: 120 mm fan x 1
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7 x Expansion Slot
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
21 cm
49.7 cm
43 cm
Resources
The following resources are available for the Corsair Carbide Series 200R Compact ATX Case
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Understated & Elegant
Reviewed by Charles R on 03/06/2013
Not the cheapest, but certainly reasonable value-for-money.
Understated, elegant & robust mid-sized* tower case (*Corsair call it compact) finished in a lustrous black. The front panel is plastic but the rest of the exterior is steel, painted to achieve a similar finish to the plastic.
Plenty of room for a motherboard and all the power & SATA wiring to be neatly routed around. There are 4 SSD, 4 HDD & 3 5 1/4" slots (the 5 1/4" slots are for front mounting devices such as a DVD writer). There is no provision for a 3 1/2" front mounted device, such as a memory card reader - hence the loss of one star.
Both case fans are quiet and provide ample cooling for my AMD A10 5800K & Gigabyte MoBo.
The case is supplied with screws to suit SSDs, HDDs etc, as well as extra grommets to mount more fans if you need more cooling and tie-wraps to neatly restrain the wiring.
I've now built two PCs using this case and the results have been very pleasing.
Scroll to top
