Click to visit BT.com
BT.com
Wishlist
Corsair AX1200i 1200W Digital ATX Power Supply 80 PLUS® Platinum
Price Drop! Usually £299.99!
Price Drop
Limited Time Offer
Quicklinx: 86R7WS00
Mfr#: CP-9020008-UK
Power Rating: 1200Watt
£272.98
Corsair AX1200i Digital ATX PSU: complete digital control
The revolutionary AX1200i is the first desktop PC power supply to use digital (DSP) control and Corsair Link to bring you an unprecedented level of monitoring and performance customization. The DSP in the AX1200i makes on-the-fly adjustments for incredibly tight voltage regulation, 80 PLUS® Platinum Efficiency, and clean, stable power.
Real-time monitoring and control with Corsair Link
Put the AX1200i under your control by connecting it directly to a USB header on your motherboard with the included cable, or to a Corsair Link Commander (available separately). Then, download the free Corsair Link Dashboard software for unrivaled power supply monitoring and control options.
Monitor power input and output, efficiency, fan speed, and internal temperature, directly from the Windows based application. Or, take it to the next level and set up and modify fan speed profiles, or even select from virtual “single rail” or “multi-rail” software modes, with selectable OCP points.
Stable and Reliable Power Delivery
DSP-controlled, real-time voltage regulation helps ensure that your valuable components receive clean, stable power.
Less Heat and Lower Operating Cost
AX1200i's extreme efficiency earns it coveted 80 PLUS® Platinum certification. Less wasted power means minimal excess heat. This can reduce the strain on your other components, and it can save you money over the long run in the form of lower power bills.
Quiet Operation at low loads
Super-high efficiency has another benefit: silence. The thermally-controlled fan doesn't even spin at low loads. It's ideal if you're building a quiet PC or you just want to reduce the amount of ambient noise in your life.
Easy installation and cable routing, with better airflow
The fully modular cable set allows you to use only the cables you need, and the flat design makes cable routing much easier in tight spaces. You get a clean-looking system build with cables out of the airflow path for efficient space usage that's energy efficient as well.
The fully modular layout allows you to use only the cables you need, and the Self Test button makes it easy to check the status of your PSU.
  • Digital Signal Processor (DSP) for delivering extremely clean, efficient power with real-time adjustments.
  • Corsair Link™ Integration for monitoring and adjustment of performance, noise, and OCP settings.
  • 80 PLUS® Platinum Efficiency for lower power usage and energy costs.
  • Fanless operation at low loads, for outstanding noise reduiction.
  • 140mm thermally controlled double-ball bearing fan spins up as needed.
  • Fully Modular low profile cables for easy installation and less clutter.
  • Engineered to meet maximum power output at a server-grade 50C temperature rating.
  • Self-test switch to determine PSU functionality even before installation.
Corsair AX1200i 1200W Digital ATX Power Supply 80 PLUS® Platinum Bundle deal on Corsair AX1200i 1200W Digital ATX Power Supply 80 PLUS® Platinum
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£292.51
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£282.97
Resources
The following resources are available for the Corsair AX1200i 1200W Digital ATX Power Supply 80 PLUS® Platinum
Brand: Corsair
Price Range Inc VAT: 150 - 300
