BT.com
Wishlist
Corsair 8GB (2x4GB) DDR3 1866Mhz CL9 Vengeance Red Performance Desktop Memory Kit
Delivery
Standard Due date unavailable
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-10-9-27, 1.5V for motherboards using AMD, Intel dual channel processors and 2nd Generation Intel Core Processor platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
  • 8GB (2x4GB) DDR3 for AMD, Intel Dual processors and 2nd Generation Intel Core Processor platforms
  • 1866MHz
  • 9-10-9-27 latency
  • Vengeance Red heat spreader for styling and performance
  • Intel XMP (Extreme Memory Profile) Support
  • Limited Lifetime Warranty
Specification
  • Density: 8GB (2x4GB Module)
  • Speed: 1866MHz
  • Timing: 9-10-9-27
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
Corsair Vengeance - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-15000)
Latency Timings
CL9 (9-10-9-27)
Intel Extreme Memory Profiles (XMP), Vengeance heatspreader, unbuffered
Voltage
1.5 V
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-10-9-27)
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Resources
The following resources are available for the Corsair 8GB (2x4GB) DDR3 1866Mhz CL9 Vengeance Red Performance Desktop Memory Kit
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Good upgrade - high quality
Reviewed by Ste on 03/12/2011
Part of an upgrade from 4Gb to 8Gb. Wanted to get some high performance RAM to compliment a system that could cope with some overclocking in the future so went for this. Got a new found love for all things Corsair as I find their quality excellent and after care appears pretty good too
Scroll to top
