Click to visit BT.com
BT.com
Wishlist
Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Red Performance Desktop Memory Kit
Quicklinx: 7J69WS00
Mfr#: CMZ8GX3M2A1600C9R
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: Non-ECC
Express delivery Delivered on Wednesday
Hurry, only 1 left in stock!
£36.93
Overclocking Memory from Corsair - the Leader in Performance Memory Solutions
Vengeance Performance Memory Module 8GB (2x4GB) DDR3 1600MHz CL9 Unbuffered DIMM Memory for AMD, Intel Dual Channel DDR3, and upcoming 2nd Generation Intel Core™ platforms.
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
Key Features
  • 8GB (2x4GB) DDR3 for AMD, Intel Dual processors
  • 1600MHz
  • 9-9-9-24 latency
  • Vengeance red heat spreader for styling and performance
  • Intel XMP (Extreme Memory Profile) Support
  • Limited Lifetime Warranty
  • Density: 8GB (2x4GB Module)
  • Speed: 1600MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
Corsair Vengeance - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL9 ( 9-9-9-24 )
Intel Extreme Memory Profiles (XMP), dual channel, Vengeance heatspreader , unbuffered
Voltage
1.5 V
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Red Performance Desktop Memory Kit Bundle deal on Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Red Performance Desktop Memory Kit
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£56.46
saving £8.26
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£41.02
saving £1.39
Resources
The following resources are available for the Corsair 8GB (2x4GB) DDR3 1600Mhz CL9 Vengeance Red Performance Desktop Memory Kit
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1600MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-12800
Brand: Corsair
Price Range Inc VAT: 0 - 50
