BT.com
Wishlist
Corsair 8GB (2x4GB) DDR3 1600Mhz CL8 Vengeance Blue Performance Desktop Memory Kit
Delivery
Standard Due date unavailable
Corsair Vengeance memory modules are designed with overclockers in mind. Vengeance DIMMs are built using RAM specially selected for their high-performance potential. Aluminum heat spreaders help dissipate heat, and provide the aggressive look that you want in your gaming rig.
Corsair Vengeance - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL8 ( 8-9-8-24 )
Intel Extreme Memory Profiles (XMP), dual channel, Vengeance blue heat spreader , unbuffered
Voltage
1.5 V
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL8 ( 8-9-8-24 )
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
