BT.com
Wishlist
Corsair 8GB (2x4GB) DDR3 1600Mhz CL11 XMS3 Performance Desktop Memory Kit
Delivery
Standard Due date unavailable
Corsair's mainstream memory solution for the Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair's new XMS heat spreaders, each module is built using carefully selected RAMs.
  • Two matched 4GB modules for use in high performance for the Intel Core i7, i5 and i3 Dual Channel systems
  • Outrageously fast 1600MHz performance using 8GB of memory
  • Low 11-11-11-30 latency
  • 10 Years Manufacturers Warranty
  • Density: 8GB (2x4GB Module)
  • Speed: 1600MHz
  • Timing: 11-11-11-30
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.50V
  • Warranty: 10 Years Manufacturers Warranty
Corsair XMS3 - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1600 MHz ( PC3-12800 )
Latency Timings
CL11 ( 11-11-11-30 )
Black XMS heat spreader, dual channel , unbuffered
Voltage
1.5 V
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
