BT.com
Wishlist
Corsair 8GB (2x4GB) DDR3 1333Mhz CL9 XMS3 Performance Desktop Memory Kit
Delivery
Standard Due date unavailable
Corsair's mainstream memory solution for the AMD Phenom II or Intel Core i3, i5 and Core i7 dual channel memory processors and platform. The XMS3 family is Corsair's mainstream line of performance DDR3 memory. These modules allow users to experience outstanding memory performance and stability. Available in Corsair's XMS heat spreaders, each module is built using carefully selected RAMs.
Corsair XMS3 - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz ( PC3-10600 )
Latency Timings
CL9 ( 9-9-9-24 )
XMS heat spreader, dual channel , unbuffered
Voltage
1.5 V
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-9-9-24 )
Non-ECC
Voltage
1.5 V
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
