BT.com
Wishlist
Corsair 8GB (2x4GB) DDR3 1333Mhz CL9 Value Select Desktop Memory Kit
Delivery
Standard Due date unavailable
Corsair built its reputation on performance memory that shines in the most demanding computing situations: extreme gaming and high-transaction processing environments. But not all computers are put to such extreme usage. So we brought the same reliability, testing and Corsair quality to a line of memory designed to support standard computing situations such as popular office applications. Now it's one of our most popular memory lines. Backed with a lifetime warranty, it is memory you can rely on.
  • 8GB Kit (2x4GB)
  • DDR3 1333MHz DIMM
  • 333MHz
  • 9-9-9-24 latency
  • 10 Year Warranty
  • Density: 8GB Kit (2x4GB)
  • Speed: 1333MHz
  • Timing: 9-9-9-24
  • Type: DDR3
  • Format: DIMM
  • Pin Out: 240 Pin
  • Voltage: 1.5V
  • Warranty: 10 Years
Corsair Value Select - DDR3 - 8 GB: 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB: 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9 (9-9-9-24)
Unbuffered
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 (9-9-9-24)
Non-ECC
Unbuffered
Compatible Slots
2 x memory - DIMM 240-pin
Scroll to top
