BT.com
Wishlist
Corsair 8GB (2x4GB) DDR3 1066Mhz CL7 Apple SODIMM Certified Apple Mac Memory Kit
Sorry but this product has been discontinued.
View used stock
Delivery
Standard Due date unavailable
Corsair Mac Memory, 8GB 1066MHz C7 DDR3 SODIMM for Apple iMac, MacBook and MacBook Pro 4GB (2x4GB). Tested at Apples compatibility lab to ensure functionality with all current products that have official Apple support for 4GB SO-DIMMs. Adding system memory is one of the most effective ways to improve overall performance and Corsair's Mac Memory offers a solid tested solution with a limited lifetime warranty.
  • Tested at Apple's compatibility lab to ensure functionality with all current products that have official Apple support for 4GB SODIMMs
  • World famous Corsair reliability and performance
  • Dual Channel
  • DDR3 Memory
  • 10 Year Warranty
  • Density: 8GB (2x4GB SO-DIMM)
  • Speed: 1066MHz CL7
  • Timing: 7-7-7-20 (1066 MHz)
  • Type: DDR3
  • Format: SO-DIMM
  • Pin Out: 204
  • Pin Voltage: 1.5V
  • Warranty: 10 Years
Corsair Mac Memory - DDR3 - 8 GB : 2 x 4 GB - SO-DIMM 204-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
1066 MHz ( PC3-8500 )
Latency Timings
CL7 ( 7-7-7-20 )
Unbuffered
Voltage
1.5 V
Apple iMac; Mac mini; MacBook; MacBook Pro
8 GB : 2 x 4 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL7 ( 7-7-7-20 )
Non-ECC
Unbuffered
Voltage
1.5 V
Compatible Slots
2 x memory - SO-DIMM 204-pin
Apple iMac , Apple Mac mini , Apple MacBook , Apple MacBook Pro
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Great boost to MAC
Reviewed by TR on 27/05/2013
I have added 16GB to my late 2009 27iMac and it works just great. For £43 per 8GB this is a really cheap way to boost an iMac performance. BT service was just great and just 99P delivery.
1* Didn't work in my early-2009 iMac
Reviewed by Anonymous on 09/05/2013
I bought these modules for an early-2009 iMac 24". The spec is supposedly correct (according to the Apple website), but on power-on the computer just made 3 beeps and wouldn't boot. I tried both modules separately, and both showed the same problem. So much for Certified Apple Mac Memory!
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition This item has been opened and is in excellent condition.
Ref: 7J6C 035820
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£41.74
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
