Click to visit BT.com
BT.com
Wishlist
Corsair 8GB (2 x 4GB) Vengeance Pro Red DDR3 2133MHz CL9
Quicklinx: 8QJ4WS00
Mfr#: CMY8GX3M2B2133C9R
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 2133MHz
Data Integrity: Non-ECC
Standard delivery Delivered within 3-5 working days
6 in stock
£50.62
Corsair Vengeance Pro Series memory modules are designed for overclocking on the latest 3rd and 4th generation Intel® Core™ platforms, with eight-layer PCBs and ICs specially selected for performance potential. The aluminum heat spreaders provide superior temperature management and have the aggressive look you want in your gaming rig. XMP 1.3 profiles allow for automatic, reliable overclocking.
They're available in multiple colours to let you match your Vengeance Pro memory to your system's color scheme. As a bonus, they're priced to deliver class-leading value, so you'll have more room left in your system build budget.
Corsair Vengeance Pro Series - DDR3 - 8 GB : 2 x 4 GB - DIMM 240-pin
RAM memory
8 GB : 2 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC3-17066 )
Latency Timings
CL9 ( 9-11-11-31 )
Aluminium heatsink, dual channel, Vengeance heatspreader, Intel Extreme Memory Profiles (XMP 1.3) , unbuffered
Voltage
1.65 V
8 GB : 2 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
Latency Timings
CL9 ( 9-11-11-31 )
Non-ECC
Voltage
1.65 V
Compatible Slots
2 x memory - DIMM 240-pin
Corsair 8GB (2 x 4GB) Vengeance Pro Red DDR3 2133MHz CL9 Bundle deal on Corsair 8GB (2 x 4GB) Vengeance Pro Red DDR3 2133MHz CL9
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.62 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£70.15
saving £8.68
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£60.61
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-17066
Brand: Corsair
Price Range Inc VAT: 50 - 100
